Carpet/ rear seat removal help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Mar 12, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    Ok
    well i need some help. 1st i need some help on how to remove my rear seat to my 85. because i am gonna put herculiner in the rear.
    also any tips or tricks when it comes to removing the carpet?
    thanks for the input guys
    email me Confederate9@aol.com
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    To take the seat out just flip it up and unbolt the telescoping supporting rod then unbolt the two bolts in front and it comes right out. To take the carpet out remove the rear trim plate(holds carpet down) and the front trim plate(plastic piece by the passenger footwell) and the spare tire mount and it comes out. Then take out the insulation. The trickest part is removing the carpet on the wheelwells because it's glued on. Try to get most of the carpet off, then try using a paint scrapper, acetone, or a wire wheel(wire wheel was the most messy but the quickest route) to remove the glue
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I just did this a week or so ago. there are 3 bolts that hold the seat on, 2 at the front and one on the side wall at the end of the shock looking thing. Take them out. Now your seat is out. Unscrew the screws for the carpet and take it out. Be really careful with that black tarpaper junk if you are going to reuse it. Its pretty straightforward, good luck.
    90K5
  4. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    thanks guys,
    im not planning on reusing the stuff.
    so it wont be too difficult eh?
  5. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    There is no real trick to removing the carpet or rear seat. The seat is just 2 bolts at the pivot under the seat and one shoulder bolt at the 'locking' arm going into the side of the fenderwell. The carpet may be glued down, mine was. It was so badly rotted I just ripped the thing out. The hard part will be getting the fenderwell carpet off...definitely glued, but usually not rotted so they'll come off in one piece.
    Hopefully the inside of your truck hasn't seen too much moisture or the bolts may be rusted. Mine were a little tough to remove but not so bad. A friend of mine snapped all three bolts...[​IMG]
    If the bolts come out instead of breaking clean the threads and nev'r-seez them before you put it back together.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  6. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    i broke the two bolts that go through the floor, had to drill them out and put new ones in....frozen solid
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
