carpet removeal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, May 22, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Is it hard to remove carpet form a blazer. Is there eneything special I need to do to get it out.
    I am preparing it to be line-xed
    Go prepared
    90 k5 soon to be big, bad, and mean
  2. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    The hardest part is getting the seats out if the bolts are rusted into the floor. Also, the carpet on the wheel wells is glued on so it tears apart when you pull it off. Other than that it comes out pretty easily.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    Proud owner of an 88 Jimmy
  3. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    It's pretty easy to do. You have to pull all of the seats and seat belts out and them reinstall them. The counsel has to come out and also the door sill plates (aluminum things holding the weather strip down. You may also have to pull some panels (one right below rear seat) and that's about it... don't be too suprised to see the ground through the rust holes!
    NEVER been stuck... *yet* (4wheeling)
    Stuck for 10 months (At school)
  4. James90
    May 18, 2000
    986
    Rocky Mount NC
    My k5 is a 90 and the under side looks good so I hope there is no rust but that is why I am going to go thru all this work and money to line-x it to stop rust I hope and I thank it will look cool and clean up easy
    Go prepared
  5. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    I have an '89 that's rusted to s&*t and I thought that it wasn't that bad when I bought it... boy was I wrong!!
  6. James90
    May 18, 2000
    986
    Rocky Mount NC
    I gess I will see when I take off the carpet but I am hopeing for the best
    Go prepared
  7. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    That's what happened to me too. I'm in the process of fixing it now. The entire floor, front to back, has to come out. The lower side panels where the seat belts mount fell apart when I took the carpet off. I'm tempted to take the truck back to the dealership I got it from 8 months ago and ask them how it passed their inspection. If I had ever gotten into an accident I would have been in serious trouble. I hope yours is in better shape than mine. Good luck.
    Joe
    88 Jimmy
