carpet/rust/undercoating questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Sep 13, 2000.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    Lastnight i got a wild hair up my ass and took out all the carpeting in the back, and found that the padding was starting and trying to mold and decompose...(weird greasy mold stuff) and also found a few places where rust was begining to form, i was wondering if anyone else had any ideas or tips to prevent further rust from forming..im thinking of duplicolor "bedlinering" or rustolium the back and then putting new insulation in, also thinking of spraying the bottom of the rig with rubberized coating for rust and noise, i was wondering if there was any tips to make this look good and to do it right...?? thanks for any help!!open to all suggestions and ideas
  2. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    THE FIRST THING I WOULD DO WOULD BE TO USE A WIRE BRUSH EITHER AN ELECTRIC OR MANUAL ONE AND SCRAPE ALL THE RUST OFF. TRY TO GET ALL THE RUST OFF AND WIPE IT CLEAN. THEN YOU CAN PUT IN A ROLL IN LINER OR COATING OF YOUR CHOICE. THE IMPORTANT PART IS REMOVING ALL THE RUST OR IT WILL COME BACK AND EAT UP THE METAL SOME MORE.
    DAZED AND CONFUSED IN A 74 BLAZER
    ZEPPLIN
  3. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    You could also try out some por 15 if you wanted to keep a smooth look in the back and place the capet back down i just appiled there product around my battery tray area and i don't know if it will work out in the end because time is the determing factor but it looks nice.
    anthony
  4. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
    I would suggest getting some Corroless from Eastwood Company - I have used this product extensively on my vehicles. You can buy it by the pint, quart or spray. If you get a can it can be thinned to use in a spray gun. It only comes in one color (maroon), but can be top coated with almost anything. THIS STUFF WORKS! Just prep the surface with a wire wheel or brush and you are good to go.
    I would also recommend the Eastwood Co. catalog as a source for many other products. But BE CAREFUL! They sell so much good stuff your bank account will suffer!
    -WOODMAN 89K5
  5. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    The woodman speaks the truth, corroless rocks! I applied it years ago and the rust was halted. Makes a great primer too, if you just want decent results. nothing beats a sandblaster, welder, and angle grinder for perfect factory results though. The little 99.00 wire feed welder at Wal-Mart is great for sheet metal.
    "who dares wins"
  6. Woodman89
    Jul 27, 2000
    60
    New Hampshire
  7. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Woodman's right, Eastwood rules. They've got great supplies and tons of tools to make your life A LOT more enjoyable.
    Archer, $99 for a welder at Wal-Mart?! I might be coming home with a welder today!
    It's not what you buy, it's what you build!
  8. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    We duplicolored our bed for the exact reason..to keeo it from getting rusted from water...Seems to be holding up great. Also did an undercoating to for sound...I agree tho, make sure you get all that rust off first. There is also stuff at Wal-mart for about 3.00 a bottle it removes rust down to the bare metal, with no scrubbing. Works great. Naval Jelly, but I forget the name wal-mart has on it...it is with the auto paints and primers. white bottle red label..amazing stuff... It is usually right next to the rust converter...same company... just my 2 cents,
    http://www.rockosangel.coloradok5.com
    http://www.rocko.coloradok5.com
  9. EDGE
    EDGE Registered Member
    Aug 12, 2000
    42
    virginia beach , va
    what's up? I've been thinking of doing the same thing,but I've been doing some research about do it yourself bedliners.If you are going to use one,use something like herculiner.The materials are way better than duplicolor.The end result looks much better and more durable.Its more like a rubber coating as opposed to a hard finish that has a tendency to crack and scratch easily.
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  11. K5XLR8R
    Aug 22, 2000
    210
    Washington State
    thanks all for the suggestions!!...now i need some ideas about how to go about applying the undercoating...?? Also any techniques on mud and dirt removal under the body...areas to watch for...?? thanks again!!
  12. K5XLR8R
    Aug 22, 2000
    210
    Washington State
