Carpeting ??
Discussion in 'The Garage' started by big pappa b, Jul 2, 2004.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Anyone ever use carpeting from a carpet store rather than the molded stuff that is made for the K5? I ripped my front carpeting out yesterday. It was well worn and rotted along with the padding and tar stuff underneath. I found a place online for the front set of carpet for $96 and it's molded. I think I can get stuff from local carpet store for $50-75. Just wondering if I should just get the other though
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    it would work but usally you have a hard time getting it to conform to the contour of the floor pan
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    carpet is stupid!!!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've used it in a couple of different vehicles over the years. You'll need to buy some strong thread and big needles. Why? Because you're going to have to cut out small wedges of carpet here and there to get rid of wrinkles. /forums/images/graemlins/eek.gif You find the wrinkles and then cut out a tapered section, basically following the lower edges of the wrinkles. Once you have it trimmed so that the carpet lays flat, then you have to sew those two sections together and move on to the next wrinkle. It's a pain in the a$$ but your rig will be VERY quiet inside when you're finished. Home carpet is much thicker/heavier than auto carpet. /forums/images/graemlins/cool.gif Pay extra special attention in the area under the gas pedal. You don't want the carpet hanging it up. /forums/images/graemlins/shocked.gif
    It's much less work to drop in a new piece that is already molded to the contours of the floor. /forums/images/graemlins/thumb.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't laugh but I can sew up hackey sacks from scrap leather. The easiest needles and thread to use , and would work on carpet is fishing line and leather needles. I push it through with a small needle nose. Should work on carpet too /forums/images/graemlins/k5.gif
  6. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    Might want to check out West Marine. Little pricey but it's UV/water resistant. I really beat up my carpet and it's held together great.
    ....depending upon your need for detail (read: every contour vs. general sound dampening) = disclaimer
    Nate
