Carriage Bolts in bed removal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BKinzey, Nov 13, 2006.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    After removing the rubber body mounts I noticed the bolts are in bad shape. In the bed I see a blob of weld on the bolt so I ground that off. I thought before I go beating on the bolt from underneath to remove it I should ask if that's all I need to do:o
    Any suggestions on how to keep or delay the new bolts from rusting away?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I just use grade 8 bolts when putting a bed back on. The coating on the bolts will outlive me.
