carrier bearing caps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerus, Sep 30, 2001.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Dose anyone have the tourqe specs for the bearing caps on a dana 44..
    colin
    Save the whales Harpoon a fat chick.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Here ya go:
    SPECIFICATIONS
    Ring Gear Diameter 8.5"
    10 3/8" X 24 RH Threaded Bolts
    PINION Diameter 1.376", 26 Spline
    CASE: 3.73 & Down, 3.92 Numerically Higher
    8620 Material Heat-Treated
    19 Spline Rear Axles on Jeep to 1970
    30 Spline Front & Rear Axles
    Assembly Specifications:
    Cover Bolt Ft. Lbs. 30-40
    Pinion Brg. Preload In. Lbs 20-40
    Pinion Nut Ft. Lbs. 200-220
    Ring Gear Backlash .005-.008
    Ring Gear Bolt to case Ft. Lbs. 45-60
    Side Brg. Caps Ft. Lbs. 70-90
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    thanks for the info man helped me out alot thanks again.
    colin
