carrier bearings
Discussion in 'The Garage' started by dammit32, Nov 8, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    what do they act like when they are going?
  2. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    The most common thing to notice is grumbling on deceleration. Best way to check is to pull the cover and check the fluid. If a carrier bearing is going out, you'll usually get metal shavings in the fluid. You can get more involved and take off the bearing caps and look at the bearings and races. Just make sure you keep track of which side everything was on.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    if they are really bad you should get a little side to side play in the carrier it self.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
