Carrier Break?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Feb 21, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, I was wondering the carrier break on a front 10 bolt axle. I currently have 3.73 gears and am planning on 4.56 gears. Will I need a new carrier. Also will a Auburn limited slip from a rear 10 bolt work in a front axle. Thanks
    Harley
    My Chevy isn't broken, its just out of gas.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    No, I do not think you need a new carrier. I went from 3.73 to 4.56s and no one said anything about it. Of course, I also added Detroits which replace the carrier. But no one ever said there was an issue before.
    On the Auburn, yes it will work. Anything that will go in a rear 10-bolt will also go in the front. The only thing to make sure of is the spline count. There are 28- and 30-spline axleshafts for a 10-bolt. I don't know how an Auburn works, so I don't know if that matters for it. But just be aware.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Carrier break for 10 Bolts is between 2.73 and 3.08
    You are in the clear
    Over 600 posts and still a "pavment pounder"...
  4. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    That's why I didn't know of any carrier breaks in the 10-bolts! Man that's high!
    Brian
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Are you sure the Auburn will work up front on a ten bolt? I asked a GM mechanic about this and he said absolutely no way. The carriers are different sizes physically. I hope he's wrong!!!!!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    When I removed mine, the front and rear carriers on my 10-bolts were exactly identical. I don't see why they would be different sized anyway considering the gears are the same size! Doesn't make sense!
    And, the Detroits I put in (front &amp; rear) were identical. Only difference is that rear 10-bolt axle shafts have c-clips and fronts don't; and front 10-bolt axles have the seals inside the carriers at the innermost part of the housing where the rear axle seals are way out at the wheel end of the housing.
    Brian
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Oh man, if he's wrong I'll be stylin'!!!! I'm getting an open carrier from Jekbrown somethime soon that I'm gonna stick a lockrite into and then I'll throw my Auburn up front since it's pretty worn out anyway. It still works, just not 100%.
    Jim
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Who cares about carrier breaks? They make thick gears for everything now anyway. They're cheaper than a new carrier, just as good, and not that much more expensive than a regular gearset.
    Tim
