Carrier question
Discussion in 'The Garage' started by MTBLAZER89, May 10, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I didn't have access to a press to pull of my carrier bearings so I did what I was told was easier. I broke off the cages then used a die grinder to grind partially through the bearing then used a punch to break it. My question is I nicked the carrier a few times with the die grinder. Will this have any adverse effects on anything? Thanks
    -Brian
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Anyone? /forums/images/graemlins/1zhelp.gif
  3. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    just make sure there's no burrs and it should be fine, the bearing presses on it so it's not like it has something rolling over it.
    -Scott
  4. TNS10HYBRID
    TNS10HYBRID Registered Member
    May 4, 2003
    21
    Just knock the burrs down, there is still plenty of mating surface left.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool thanks everyone.
    -Brian
