carrier swap in D44 without changing pinion gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WARP1, Feb 25, 2003.
  1. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I have a 3/4 ton D44. I want to swap to a limited slip carrier before I put it in. It has 4.10 gears. Can I complete this swap using the existing ring and pinion (and without removing the pinion gear)? I know I'd probably need to re-shim with the new carrier.
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Absolutely. Like you stated, you will just need to re shim the carrier. Just take your old carrier out and put your existing ring gear on the new carrier and slap it back together.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yup, set the backlash and go. Changing the carrier will not affect the pinion depth (and therefore will not affect the pattern) in any way.
