Carrier swapping in 10bolts
Discussion in 'The Garage' started by berg76, Jul 26, 2003.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Can you swap a carrier out of a 10bolt rear and install it in a front 10bolt? and vise-versa? I wasnt able to find anything on this. /forums/images/graemlins/1zhelp.gif
    jason
  2. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You just have to be careful on the spline counts for the axle shafts. There was an assortment of 28 and 30 splines axles used. But you can also swap the side gears to match the splines. For example, if you have a 30-spline rear and a 28-spline front, you can swap the side gears from the front diff into the rear diff, and then install the rear diff up front. However, if you have a Gov-Loc out back, then the side gears from an open front won't swap into it. /forums/images/graemlins/frown.gif
  4. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    [/ QUOTE ]Yea, but gov-locks are gay anyway /forums/images/graemlins/thumb.gif
  5. berg76
    Nov 4, 2002
    238
    St. Louis, Missouri
    Cool, thanks for the help. /forums/images/graemlins/thumb.gif
