Carrying a Cooler
Discussion in 'The Garage' started by Polaris, Oct 7, 2002.
  1. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    /forums/images/graemlins/1zhelp.gif
    Might seem like a lame thing to have to ask about, but really I'd like to take a small cooler along when we are gone all day on the trails. How do you all keep them strapped down? Thanks for any suggestions.
  2. Grim-Reaper
    7,385
    Atlanta
    Well if it's a close to home trail then I put my tall narrow cooler in my Gerry can rack and use a zip strap (self locking nylon web strap). If I need my 20liter gas and 6 gallon cans with me then I strap them down using the roll cage as anchors. Course I doubt your truck has the stuff mine does /forums/images/graemlins/grin.gif Ace hard ware sells these really nice spring loaded tiedowns you can bolt to the floor. The spring keeps them from rattling when not in use.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i drilled two 1/2" eye-bolts into the bed and use ratchet straps. kept everything except the veggie plate and chips down going through Frame Twister /forums/images/graemlins/rolleyes.gif
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    If your just taking the cooler then I use 2 ratchet straps.
    Tilt the back seat up and feed the strap below, drop the seat down and continue feeding the strap thru the seat(between the seat and the back) then you can wrap it around the cooler top to bottom. You can also run one from the armrests on the backseat. Attach the hook to the metal bar on the back of the armrest accross the cooler to the other armrest. This one works really well if your cooler has handles to pass the strap through.
    These work well for the occasional rough ride w/o any modifications.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    LOL @ Zakk.. Good show!! /forums/images/graemlins/thumb.gif
    I just use a ratchet type strap and attach one end to my high lift,and the other to the spare tire. /forums/images/graemlins/k5.gif
  6. Polaris
    May 30, 2002
    1,182
    Loved your fender trimming pics/story! Very well commented. I'm thinking of putting some eye hooks in. I have rear seat passengers, and fasten the dog to the metal handle that you can pull up the seat with. Thanks!
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Got some tie downs from walmart and just put it behind rear seat. one strap for each handle, then connected to the metal arm rests. My cooler is a marine version that has a pretty good latch on it so it cant pop open.
  8. Polaris
    May 30, 2002
    1,182
    That's a .... cooooool .... idea - thanks! I'll probably go that route. Oh wait I just ran outside and looked and I have no armrests! How funny. Scottsdale interior. /forums/images/graemlins/rolleyes.gif
  9. Storm Trooper
    Nov 24, 2000
    4,640
    I found a simple way that really works and keeps it easy to get into. 1st, you can only do this when you take out the back seat. Get a couple eye bolts? ( --O ). I think they had no more than 2"'s of thread so they don't push through the caps under the floor. Put on a nut and a big washer and use the seat bolt-down holes. Now you can set a cooler in the middle and run two tie-downs cris-cross from the eye bolts to the bars behind the seat that lock it down. You can also run a extra strap from each eye bolt through the handle to keep it from coming forward. It really works good, is easy to get into and is Moab/Blazer Bash tested.
    If this doesn't make sence /forums/images/graemlins/confused.gif, I can post a picture. /forums/images/graemlins/grin.gif
  10. Polaris
    May 30, 2002
    1,182
    Sounds great for the weekends that I don't have the kids with (once a year!) /forums/images/graemlins/crazy.gif
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    glad you liked it! we will be doing some other jackassery, so if you are in the neighborhood, bring a sixer and join in /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
