"Carter By GM" What is this??
Discussion in 'The Garage' started by 77blazin, Dec 15, 2004.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    I need some info on this carb, should I rebuild it or should I get a new one?
    It still works but got alot of gunk on top.
    This is on my 77 blazer frame and engine that I'm restoring with a 76 body on top, the engine is all stock 350 and the Carter is a 4 barrel, I wanted to get it overhauled but other guys are telling me to get an elderbrock 750.
    Any suggestions would help.
    Michael
  2. K5HIGH
    K5HIGH 1/2 ton status
    Dec 8, 2004
    102
    harrison twp. mi.
    I WOUL SAY A 750 CARB IS TOO BIG FOR A STOCK 350. PERSONALLY I LIKE HOLLEYS. SOME PEOPLE SAY THE CARTER IS A DECENT CARB WITHOUT THE TROUBLES. IF U WANT TO SAVE MONEY REBUILD IT. IF U DECIDE TO GO NEW,HOLLEY OR EBROCK, GO SMALLER THAN A 750 ENLESS YOU PLAN ON MODIN THE 350. ALSO YOU GOT A LOVE THE "BAAWOOG" THE SECONDARYS GIVE YOU ON THE QJET WHEN YOU MASH IT!
  3. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Well pretty much a carter 4 barrel = edelbrock. That's where edelbrock got their design, purchasing it from carter. Rebuilding one is easy, just run down to your local parts store and buy a kit (around $45) and some carb cleaner. For such a low investment it's worth it to try it rather than spending several hundred on a new carburetor.
  4. dyeager535
    26,980
    So is it actually a Carter, or is it a Q-jet? The way it's written it sounds like a Carter, but I wasn't aware GM built stuff for Carter (nor can I imagine they would)...Carter built Q-jets for GM though.
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Carter also supplied their AFB's as stock 4 barrel carbs in the 60's...exact same as the Edelbrock performer carb's sold today.
    Rene
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yup , except the rods don't interchange as one is stepped and other tapered :k5: :k5:
  7. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    I've seen some Q-Jets that said "Carter" on them,I think they made them when some of GM's plants went on strike in the 70's--I remember seeing Rochester 2 barrel 2GC carbs on mopars in 1970-71 when carter workers went on strike!!--who would have thought a dodge dart would come factory with a GM carb?!!..The more you fool with cars and trucks,the more things you find that will bolt on from other makes--a carter thermoquad carb bolts right onto a Q-jet intake perfect(or vise versa!)--my friend had a 413 motor home with a junk themoquad on it--he cried about a rebuilt carb being 300 bucks,so I told him to get a Q-Jet from the boneyard--it bolted right on,just had to "tweak" the tranny throttle rod thing and it ran golden--even better than the original carter carb!...right now I have a holley "Economaster" on my 307 in the van,that really belongs on a 318 mopar--bolts right on,even the choke coil and throttle lined up perfect--I recently scored another one thats the bigger 2 barrell version (like the 2GC -1-1/2 bore rochester) for 10 bucks brand new in the box at a swap meet!--also have another puny 1-1/4 bore one like my vans--I'm tempted to put it on my 305 for better mileage,but I'm too lazy to do it in the 15 degree cold--dont feel like messing with the detent cables and other crap--might be selling it anyway---..:crazy:
  8. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,008
    609
    Pueblo, CO
    Q-jets were made by Rochester, not Carter. The "new" q-jets that Edlebrock sells are actually built by Weber I believe.
    Anyway I'd rebuild what you got for now and save the dough that you would spend on a Edlebrock carb for the gas once you get it on the road.
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I've had a few older Quadrajets that had stamped on the side "Manufactured by Carter Caburetor for GMC".
    These arent as common as most of the Q-jets thats are Rochesters, but are pretty much the same thing except one says Carter on the side, one says Rochester; regardless both are Quadrajets.
    Then, as has been stated, there are the Carter AFBs (Aluminum Four Barrels), which are essentially the same thing as an Edelbrock; both which usually say Weber on the side.
  10. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I've pulled more Edelbrocks off trucks than I can count. I've replaced ALL of them with Q-jets. Edelbrock is a great carb for rodding, but they just don't seem to work very well offroad. Save your $$ and rebuild the carb you have. It'll prolly work better in your truck than a Edelbrock anyway. I actually have an Edelbrock that I pulled of smprider112's rig a few months back. After a couple trips where he/we spent more time under his hood than on the trail we swapped on a Q-jet. Since then, his truck has had ZERO fuel delivery issues. PM him, he'll give you a first hand account.
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    I have a "Manufactured by Carter for GM" quadrajet on mine (came original on the truck). If it is a quadrajet, 750 CFM is perfect. The downfall to having too big of a carb is that at part throttle and cruise it will perform terribly and get poor mileage. The q-jet has small primaries and huge secondaries, giving it good part throttle and mileage and has vacuum secondaries which keep it from being "too big" for any engine.. Most people on this board agree, if it is on a truck, the quadrajet is probably the best way to go.
  12. dyeager535
    26,980
    If you didn't pick up on it already, that's not true.
