Case spreader needed on 14 bolts?
Discussion in 'The Garage' started by odoa3, May 24, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Trying to get everything lined up to rebuild or change out the differintial in a 14 bolt. Do you have to have a case spreader in order to get the diff. in and out or can you do it as is?
    Thanks, Heath
  2. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    no just thread the collers back and count the turns. then pry it out with a bar if stubborn. goodluck buddy.:D
  3. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    no you dont need a case spreader....i had mine out and back in no problems at all, all you have to do is loosen the side bearing nuts...just count the turns you you'll loosen it to make sure you'll apply same torque when tightening them again.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    More than likely it'll fall out once you loosen the adjusters...
    I recommend a piece of plywood under the diff so if it does fall you don't damage the ring gear.
    Rene
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You can use a screwdriver, or punch to loosen them, but the correct tool makes it a snap!
  6. mountain4x4
    mountain4x4 Registered Member
    Oct 13, 2004
    62
    I just made tool to loosten/tighten 14b adjusters in 10 min. out of 1/4"sheet. If youre rebuilding the diff, its very worthwhile to have the tool. Can't tell how much youre torquing the adjuster with a punch and hammer...
  7. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks for all the replies. I am replacing all the bearings and seals in the axles, crush collar, shims, everything. Hoping that if I do it all now I won't have to mess with for quite a while. I may be swapping in a welded diff. if I can track down the guy who has it. First attempt at this so I am sure I will be back on here with more questions. < Taking a deep breath>
