cast iron or steel????????
Discussion in 'The Garage' started by JEBSR, Jun 14, 2006.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I was fixing to order my shims to fix my pinion angle when I noticed that a company sells aluminum shims(hell no) steel shims and cast iron shims. Wouldn't cast iron be plenty strong, or should I go with the steel for over double the price of cast?:dunno:
    Oh yea are 2 1/2" shims good enough or should I go 3?
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i prefer cast. aluminum corodes out to fast up in my area of the country . seen lots of them break after 2 years or so.
    if your springs are 2.5 wide then 2.5 if 3" wide then 3" wide.
  3. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Yea tha's what I was saying. No way I'll use aluminum, but I don't know if I should use cast iron shims or plate steel shims.
  4. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Anyone know?
  5. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    aluminum doesn't corrode... it's just plain weaker. Leave a pile of steel out in the rain for 2 weeks along with a pile of aluminum... I'll bet anything I own the steel is good and rusted and the aluminum is just wet.Unless theres something in the diff oil that it doesn't like it shouldn't corrode. I've worked with cast and honestly I wouldn't use it for anything that thin... cast likes to crack... go with the forged shim. Yeah they are both iron but cast will always have more imperfections than sheet metal or forged steel. They would probably do the job but I wouldn't be suprised if they cracked either.
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I ran a pair of cast iron, 6-deg shims and I had problems with them cracking at the "skinny" end. I bought a pair of steel shims from JKWOffroad and they work great, no cracking. So I would have to recommend the steel.
  8. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i apologize for this know it all reply but if you bolt that steel shim and that aluminum shim together in water for 2 weeks the aluminum will absolutely corrode. this is why sacrificial zinc anodes (the little fin behind the propeller) are mounted on outboard motors. the zinc rots away and all other metals in the motor are left intact. each metal(alloy or element) is ranked by its tendency to corrode while in contact with a different metal. corrosion is a chemical reaction where the oxygen reacts with the metal and creates Iron oxide (rust) or aluminum oxide (oxidized aluminum) for 2 examples.
    this also has alot to do with how batteries work however, batteries weren't the subject of my honorably mentioned 8th grade science fair project. "Corrosion of Metals"
    aluminum "rust" is white, copper "rust" is green-blue
    and iron rust is red-brown.
    for the record i have two 2"x2"x7" lowering blocks installed between my rear trailing arms and my rear axle for 2" of drop in my 1970 2wd blazer. i made them out of some leftover 8/4 quartersawn boards of white oak i had in my basement.
    all i'm saying is f*** it, you wanna live forever!?
  9. beastofablaze
    Apr 4, 2005
    441
    CA
    no worries
    But I have to say I've had different experiences with both... apparently I was looking for the wrong kind of rust.
    Good info man.
  10. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    yup, come visit the marine industry for a week...
    I just replaced a $1200 Merc intake manifold on an old hotrod Merc 454, all stock, 370 horse.. Late 80's Cigarette boat.. The front 2 corners where corroded past the mounting bolts to the point where the water jackets where so paper thing, water was seeping thru... I'll take a pic monday... big pile of white, fluffy goop...
    Oh, and personally I'd go for the steel shims, high abuse area....
