Caster angle
Discussion in 'The Garage' started by mudjunkie 82, Jan 4, 2005.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I need to rotate my front 60 for a better pinion angle, Does anyone know the most you can go before it really effects caster angle? my caster is 7 degrees right now. Thanks for any info
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    id like to know also
  3. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Where is Tim when you need him:confused:
  4. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Who needs him?:D
    For every degree you rotate the axle you change the caster the same amount. 7 degrees is in the ballpark.
    When you turn the steering wheel, the front wheels respond by turning on a pivot attached to the suspension system. Caster is the angle of this steering pivot, measured in degrees, when viewed from the side of the vehicle. If the top of the pivot is leaning toward the rear of the car, then the caster is positive, if it is leaning toward the front, it is negative. If the caster is out of adjustment, it can cause problems in straight line tracking. If the caster is different from side to side, the vehicle will pull to the side with the less positive caster. If the caster is equal but too negative, the steering will be light and the vehicle will wander and be difficult to keep in a straight line. If the caster is equal but too positive, the steering will be heavy and the steering wheel may kick when you hit a bump.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    but how much can you rotate it without it wondering to much?
  6. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Ditto??????????????????????????????????????????????????
  7. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    I set the race truck up with 8* caster. I don't know the factory specs off hand, but could look them up at home if no one else knows them. I would think 6* would be optimal and 2* would be sketchy at best. Get yourself (borrow) some caster shims and install them to try different settings before you do any cut ‘n turnin’. You’ll know when you have gone too far.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im pretty sure the factory caster is 8*
    i need a 6* shim to get my pinion angle right, but have been thinking about going with a 4*
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    What is the best way to measure the castor you currently have? I assume an angle finder will work but where do you place it?
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes 8* is correct. I looked it up when I had my knuckles put on.
  11. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    :ears: :ears: :ears:
  12. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    AFAIK, You can not accuratly measure caster ange in your garage unless you have an alignment rack. It has to do with the steering inclination angle (SIA) and the changes encountered when you turn the wheels.
    I could be wroung though as it has happened before. If anyone knows a way to do it i will buy you a beer or three for telling me.
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the only way i know is to remove the knuckle and get a bar to just fit inside the holes for the ball joints and stick a angle finder to it. youll also have to account for the angle of the entire truck.
    its alotof work just to measure that, but it should work.
  14. divorced
    Jul 20, 2004
    5,115
    Maybe I'll just take my $40 to the alignment shop and see. They can set my toe then too. :D
  15. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    A top the knuckle
  16. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    From what I understand 4* positive caster is the least you should ever have. Don't quote me on this as it is hear say. I know there are lots out there that have less caster than that.
    Don't try to flat tow anything with much less than that. It just don't work.
