Caster settings on a SFA Chevy?
Discussion in 'The Garage' started by sled_dog, Oct 15, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Alright if my memory serves me right the factory Caster angle on a 73-91 Chevy is 7*. Can someone explain why this is?
    I mean with a load in the bed it will only go more positive. It seems to me we have more then a few degrees of caster to play with to set it up where we want it.
  2. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    I dont think caster really changes with a load in the bed.I don't know what the factory spec. is but I would love to.How much are you trying to play with?
  3. bernman
    bernman Registered Member
    Oct 4, 2005
    26
    ny
    depending on how sagged the front and rear springs are you should have 7-8 degrees of caster, that all needs to change once lifted though, and anytime the rear of the vehicle is loaded or lowered the caster will increase
  4. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    So does anyone know what the minimum amount of caster that is acceptable? As in how many degrees can the front axle be shimmed before caster is unacceptable without spinning the axle tubes.
  5. bernman
    Oct 4, 2005
    26
    ny
    it depends on where and, how you drive i have about 6.5inches of lift, and about 4 degrees of caster on my blazer, and pinion angle is very acceptable, i think most people will find this acceptable for their rigs.
  6. bernman
    Oct 4, 2005
    26
    ny
    what are you planning to do with the truck?
  7. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    I need the truck too have decent street manners.
  8. bernman
    Oct 4, 2005
    26
    ny
    my truck drives great with 4 deg caster, yours should too
  9. 73k5blazer
    Dec 28, 2001
    4,932
    8
    The Rustbelt
    According the my 1973 GM Service Manual, and my brother, who's a tire wheel engineer for GM who looked up the spec for a '91, the K10 & K20 Alignment specs which matched the ones in my 73 GM service manual, so 1973-1991 K10 & K20 are as follows:
    Caster: +4* Not resettable (well it is sligtly if you use different length schackles)
    Camber: +1.5* Not resettable (well it is with the upper ball joint special sleeve or the camber shim between the spindle & knuckle)
    Toe: 3/16" (exc K10 w/ Full time 4wd= 0")
    Tolerances are as follows:
    Service Check:
    Caster: +/- 1*
    Camber: +/- 3/4*
    Toe: +/- 1/8"
    Camber (Sdde-to-side): 1*
    Caster(Side-to-side): 1*
    Service Reset:
    Caster: +/- 1/2*
    Camber: +/- 1/2*
    Toe: +/- 1/16"
    Camber(side-to-side): 1/2*
    Caster(side to side): 1/2*
    (Service check states: Values within these limits should provice a high level of customer satisfaction and shoud not require resetting
    Service reset states: Values that the vehicle should be set within if it observed out of the service checking tolerace or if it is being aligned due to replacment components or for any other reasons)
  10. bernman
    Oct 4, 2005
    26
    ny
    i am not referring to any spec guide, i am referring to the hundreds of alignments i have done to these trucks, and most have about 7deg of positive caster in stock trim. some suburbans come clocer to about 9deg.
    due to rear end sag.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Hunter spec book says 7*.
  12. 73k5blazer
    Dec 28, 2001
    4,932
    8
    The Rustbelt
    Just telling you what the GM service manual says, and what GM's internal database says. Those alignment machines in the field are notorious for having the wrong specifications. Take your pick.
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I vote for 7 or 8* I got mine set at 8* when the knuckles were put on.
  14. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Can someone please explain to me how caster changes with a load in the rear.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    when you load the rear the rear sags. The truck pivots on the front axle in that instance and bam the knuckles turn back as the load increases, thus creating more positive caster.
  16. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Could someone please explain a little more.The only way what your saying could actully happen(the way I see it)is if you had longer front shackles and they were at an angle(like running 52s up front).All stock front shackle angles are pretty close to 90* so I still can't picture what you'r saying.Thanks
  17. bernman
    Oct 4, 2005
    26
    ny
    when you load the rear of the truck, the rear squats down and your trucks frame angles backward, now since your front axle is permantly bolted to your frame via leaf spings, the front axle also leans back (or positive) this is true for all vehicles. the opposite is also true, if you lift the rear, caster will move in the negative direction.
  18. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Who works at an alignment shop and can actually see how much the caster changes on a loaded truck, if at all? Anyone?
  19. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Xs 2
  20. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    I can see it changing a degree or two, especially if it were a very shortbed like a blazer. But I think it would have to be loaded DOWN, like with a ton of concrete to be noticeable
