casting numbers needed
Discussion in 'The Garage' started by darkshadow, Feb 26, 2005.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    what does every one use to run them?
    i usuly use mortec
    but no luck help a guy out.
    this is a rare moter, and i dont expect it to be easy, i expect most not to have hurd of it, and i need to see if i can find rings and gaskit sets for it.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well what is it ? Is it a 348-409 ? what casting number ? I would love to waste away days at work next week searching :D
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah why dont you give us stamping and casting codes off it
    we would like to see front stampings, and rear castings and cast date too
    i always use mortec, nastyz28.com,. etc.,
    good luck
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    ok if you guys can run it cool
    if some one can find it a gaskit set and rings even better.
    it is a 287
    14010289
    we think these got made only for the checkered cabs back in the day.
    and a few got put into other cars we hurd lemans, this moter is strong runlike a clock, with 125 psi in each cyl, and real clean inside to gunge to nothing.
    it will be the new econo moter for my buddys jimmy
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i dont know sude its a sbc, my buddy thinks it was from the 80s.
    it was no amc car, it was in a lemans that got smacked up and it had low miles so some one put in in a chevy van, and my buddy got it off him.
  7. diesel4me
    Jul 24, 2003
    17,581
    945
    Massachussetts
    pontiac lemans??
    If its definately a small block chevy motor,its probably a 267 V8,they put them in malibu's,impala's and pontiac lemans and chevy monza's from 78-82...If its a pontiac motor it could be a 265 V8,it will look just like a pontiac 301-400 motor externally..
    Do you have the code #s??--if so,post them and I'll see if any of my books list them...:crazy:
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well , was it a good read , you are one number off for a 267
    267 is 14010280 , 79-82 model years , 2 bolt mains
  9. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah i knew you guys wouldent belive me so i took pics
    here, it very clearly says 287, it moter is supper clean, and nice, 125 psi in all the clys and clean out side like it never saw winter.
    up here moter are not pritty
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    get the numbers off this pad and it should come up with something.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I still want to thinkits a 267 . No offense , maybe clean the casting number off some more . The one number , if it is 287 , could of been a mistake or something at the factory . But the end of the dirty number looks like a 0 and not a 9 :dunno:
  12. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    the glare in the pic does mess it up a bit, i should have checked it then, but there is no mistake it is a 287.
    my buddy said he found (not sure where) that it was put in the checkerd cabs the new nork ones you know.
    and also he had found another one in the paper and that was from a le mans too.
    since it runs like a top, he doent want to pull the heads yet, untill he knows he can get gaskit and ring sets.
  13. dyeager535
    26,982
    191
    That "287" number alone makes you think it's a 287? GM used 3 digit codes all over engine blocks, I wouldn't expect that to be a 287...by that time, they would have been using liters as an indicator of size anyway. That 287 is going to be a mold ID or something equally mundane.
    I have a feeling thats nothing more than some small bore SBC (262, 265, 305, etc) that just doesn't use a common (or one that anyone cares about) casting number and thats why no record online.
    As someone else asked for, whats the suffix code on that small pad? If it's blank, it could also be a factory replacement.
    If it is a lemans motor I'll bet money that the Lemans didn't have anything but standard GM engine fare that year. GM didn't waste time certifying seperate engines for emissions if they didn't have to. There were no "oh we have this lying around, lets drop it in" at that point in history.
    The less options they had in the drivetrain, the less EPA certification hassles, and in the cars, GM certainly didn't offer any more engine options than they had to. Way too much speculation, at this point origin is heresay and not going to be proven unless the suffix code checks out.
  14. dyeager535
    26,982
    191
    Speaking of which:
    1979-82 14010280 267 2 bolt car
  15. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    its not mine so i cant check the suffix code ans dident get it on the weekend.
    ill call and ask him some time soon/.
