Casting #'s to determine ratio?
Discussion in 'The Garage' started by LKJR, Feb 15, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Casting #\'s to determine ratio?
    Is there a way to determine ratio by the casting # on an axle tube if it is still stock? going to pick up a 14ff tommorrow and there are 2 I"m going to choose from. be nice if I could know a ratio without pulling the cover. I guess if I had to I could spin the yoke / drum and count, if I do that what do I count into what? thanks
  2. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Re: Casting #\'s to determine ratio?
    You would probably want to pull the cover to look at the gears any way, wouldn't ya? Or are you planning on changing the ratio? It does not take but a couple of minutes to pull the cover and check out the numbers on the edge of the ring gear. /forums/images/graemlins/thumb.gif
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I just hate to do that and dump gear oil in the guys field. kind of an envirmental issue ya know.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    take a bucket and brake clean
    they could be full of water or ?? and you should know before you buy
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Done deal, picked up a 3/4T with big brakes 14B FF w/ 4.10's for $50 today, got two 2.5? gallon air tanks for $2 a piece too, with brackets to mount to my frame already on them. Been a good day. /forums/images/graemlins/pimp1.gif /forums/images/graemlins/thumb.gif
