cat diesel pics
Discussion in 'The Garage' started by gtkustoms, Oct 4, 2002.
  1. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Thats a sweet conversion!
    Is it yours?
  3. gtkustoms
    Oct 6, 2001
    281
    nm
    damm skippy /forums/images/graemlins/grin.gif
    built it myself
    not quite finished yet, but what truck is
    thanks
    travis
  4. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    3208? That thing most run real good and sound mean.
  5. gtkustoms
    Oct 6, 2001
    281
    nm
    yeah it gets it real good /forums/images/graemlins/smile.gif
    sounds great with nothin but 4" straight pipe for the exhaust /forums/images/graemlins/grin.gif
  6. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    How much does a cat engine like that cost? How did you adapt it to the trany? Which trany are you running?
  7. gtkustoms
    Oct 6, 2001
    281
    nm
    i got it out of a 7500 series GMC truck
    it is hook to the tranny that came out of that truck
    it is an allison automatic it is called an mt 643
    it has R,N,4,3,2,1 for gearing
    did not cost much at all /forums/images/graemlins/grin.gif
  8. azblazor
    May 5, 2001
    1,953
    So what about the transfer case?
  9. gtkustoms
    Oct 6, 2001
    281
    nm
    it seems to be missing right now /forums/images/graemlins/eek.gif
    yes its only 2wd
    has a dropped front axle in the front
    would have been another 8" taller up front if i put in one of my Dana60's
    I soooo wish it was 4wd.
  10. azblazor
    May 5, 2001
    1,953
    Still - its a cool thing! I'm thinking real hard about a perkins or a cummins for this M1008 in my backyard.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I found a 84-ish flat nosed Ford cab-over (F650?) with a 3208 in it. Air brakes, Fuller 9-speed RoadRanger. Only trouble is the crank's seized. 10.4L (636 c.i.) yumm!
    Anyway... it opens up the donor vehicle situation a little bit. /forums/images/graemlins/grin.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    cool ride.
    do you know how to decipher the Cat nomenclature?
    3208 =
    3 = ?
    2 = ?
    0 = ?
    8 = # of cylinders
  13. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Ya buddie, When I went through a diesel course at the local College. We had a 3208 on a stand, boy when that thing fired up. Woah mama! sweet. Where would one find a cheap deisel like that?
    I used to know what the #s ment as far as engine designation. Like Detroit 8v71, v8, 71cid/cyl. But I forget the Cat. stuff. I thought it may be the same but 250 cid. dosen't seem right?
  14. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    gtkustoms, just out of curiosity, what are the torque specs on that engine? 500+? Hope you have some extra rear-ends laying around as well.
    Speaking of which, those dana 60's (plural) you have LAYING around, lets hear some more about those /forums/images/graemlins/smile.gif
  15. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Now this is the type of stuff I like to see floating around these message board! 4wd or not....HOLY SH!T!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  16. heavy4x4
    Aug 28, 2002
    3,270
    I know, that thing is cool. I want to see it pull some stumps out. Or maybe whole trees!
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    How far does that combo hang out the bottom? Looks pretty severe in that first pic. Also, looks like it could be moved up quite a bit with a remote air filter box. Either way, nice project. Like someone else said, good luck keeping the rear axles in it.
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh, looks like the radiator is in the bed (no surprise it needed relocating). How much else needed done to fit that CAT in there?
  19. gtkustoms
    Oct 6, 2001
    281
    nm
    hp is rated at 250 /forums/images/graemlins/frown.gif
    torque is around 700 +- /forums/images/graemlins/grin.gifsome but i dont really know for sure
    rear axle is a dana 80... that should hold up i hope.
  20. gtkustoms
    Oct 6, 2001
    281
    nm
    yeah it could be moved up a bite but the turbo on those sits off the back of the block...then that would lead to more fab work to remove the firewall and put in a tranny tunnel...the tranny is about the size of a big block..
    as it sits now i can get in and work on every bolt, if need be..that counts for some things in my book /forums/images/graemlins/laugh.gif
    as for all of the other work:
    1.boxed frame
    2.cut frame from big truck graft on to pu frame. i was planning on leaving the 2wd chassis as original with some motor home upgrades to handle the weight....did not work
    3. mount drop axle, custom spring packs, custom mounts.
    4. find right steering box to get it to steer in the right direction. the box is mounted at a 90 degree angle
    5. build steering shafts
    6. build adjustable chromoly linkage
    7. run radiator in box
    8. tranny cooler in box
    9. fuel tank in box
    10. install dana 80 in rear, moved perches
    thats all i can think of right now.
