  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I live in Alaska and we dont have any smog testing here although I might be moving back to WA and they do smog testing. Can I take my stock cat off an put a piece of regular pipe in its place for now and keep the old cat incaase I move back to WA? Im assuming the cat will need to be taken off with a torch. How much power does this free up is the exhaust louder?
    1985 GMC JIMMY
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just like you said- cut the old cat out and weld or clamp a new piece of pipe in it's place. My 84 305 has no cat- I did notice a little bit more pep with it off. As far added exhaust noise, all you'll hear is a little bit more roar when you step on it. My exhaust volume didn't change at idle.
    Throw the factory cat in the garbage. If you have to replace it when you move, buy a new high-flow cat.
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    you'd have to find a shop that would take it off (ill-legal to for a shop to take it off in most states), but we have the same situation here...
    I took the cats off of 'Isane Ewok', and it will be taken off of 'Jedi Mind Trick' shortly...
    <font color=blue> Jeff - may the force be with you</font color=blue>
  4. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    I already have an exhaust guy that will take it off for me but if it doenst make much difference in power why take it off then ? Does it helo with gas mileage?
    1985 GMC JIMMY
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well you gotta figure it can definately help the thing breather better...
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  6. dyeager535
    26,979
    As old as it is, its probably pretty ineffective. They are not lifetime parts. However, a properly operating cat is no more restrictive than the stock single exhaust setup itself, so no, its not worth taking off to free up a couple of HP. Again, thats IF it is not broken up and restricting exhaust. I can tell you right now, you MAY have a real hard time getting anyone in WA to put a cat BACK on your truck. I know how paranoid they are, I am going to have to get a friend to put duals on my car, after calling about 10 shops, even tellingthem it was "off-road only" Obviously wanting to install a cat is not the same thing, but with the laws being the way they are, and most shops not knowing if your truck is SUPPOSED to have a cat, they may not want to touch it. WE know it is supposed to have a cat, but they won't. Another idea is if someone will cut it off for you up there, have duals from manifolds back installed, and put TWO cats on the vehicle. Again, not legal, but it will help you pass smog easier, your engine will breathe better, and with no visual here, they can't say anything about two cats.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  7. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It depends on what kinda shap your cat is in presently. Taking the cat off the camaro helped a bunch with gas milage, power, etc..
    On my '86 pickup when I took the cat off...it helped, but not as much as on the camaro. Every truck or car is different.
    No prohibiting allowed!!!!
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
