catalitic converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKE, May 29, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    I dont know how it works, I know what its for and that they can catch fire. Mine gets hotter than hates and you can smell it. what would happen if i took it off. btw i dont have to worry about smog laws
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    If it is getting hot enough to smell it, it is probably obstructed and needs to be replaced or removed. It will catch SOMETHING on fire because of the heat build-up. I have seen cars that have parked in grass burn-up because of the converter.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you don't have to worry about emissions, pull that sucker off. You can expect HP gains and better mileage......
