Catalytic Converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tybee, Oct 4, 2001.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Whats in a catalytic converter and can you take the crap thats in it out?
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  2. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    Mine had some type of beads in it, that when they hit the driveway, turned into a goo when wet. The containing material had torn, resulting in the convertor becoming clogged.
    Rather then mess around trying to work around it, I got a high flow cat from Summit, increased performance. I've heard of people driving pipes through the Cats to make them truly "high-flow", but never done it myself. I'm a tree hugger.
    <font color=red>I will not tolerate intolerance </font color=red>[​IMG]
  3. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    I had a 91 S-10 blazer with cat. It had a ceramic type honeycomb interior. I used a piece of rebar to hollow it out. It ran with a noticeable amount of more power. Problem was two years later at smog time it failed and I had to replace the cat. So I would go with the aftermaket high flow cat if I were to do it again.
    '88 Jimmy 350/700r4 3.73's 32in Maypops
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    The cat is on my toyota camry and is clogged, its $400 from the dealer new.
  5. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    just put a universal cat on it with a small mod to the exaust
