catalytic coverter removal/installation
Discussion in 'The Garage' started by myrenhouston, Mar 11, 2004.
  1. myrenhouston
    myrenhouston Registered Member
    Feb 2, 2004
    5
    how do i remove and install a new catalytic converter in my 87 k5????
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Take it to the exhaust shop and tell them what you want,,,, /forums/images/graemlins/grin.gif
  3. myrenhouston
    Feb 2, 2004
    5
    ok....i have already removed the converter by cuttin it off at the ends. now i need to kno how to remove the excess coverter ends out of the exhaust pipe and tail pipe. i hsve already bought a new direct fit cat, so after i figure out how to get the excess pieces out, it should be pretty simple from there. please help, thanx. /forums/images/graemlins/confused.gif
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I just know on the removal part. /forums/images/graemlins/tongue.gif
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    was the old converter flared, and the pipes shoved inside, or was the pipe flared and the converter ends shoved inside the pipe??? In other words, where is the pieces you are removing, inside or outside the pipe?
  6. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I usually cut the pipe as close to the end of the good pipe as I can and then split the scrap piece with an exhaust pipe chisel. Good Luck! /forums/images/graemlins/thumb.gif
  7. myrenhouston
    Feb 2, 2004
    5
    one piece inside the pipe, one piece outside the pipe
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I assume you're trying to save money instead of going to a shop? you can grind (cut a groove, peel it off like a C shape) the piece on the outside, and get it off. The inside piece will not be worth the effort, IMO, cut length off and have a shop sell you an extension piece...
