Cause and effect: engine oiling?
Discussion in 'The Garage' started by mountainexplorer, May 20, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Cause:
    Say you had a 454 with a smaller capacity car oil pan... and you swapped a larger capacity truck oil pan onto it without changing the oil pick up tube... and then you ran the motor at over 6 grand for a few passes through a mud pit.
    Effect?: What do you think?
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    cam or main bearing failure as pickup became air bound and could not supply oil pump with oil..... (just a hunch though)
  3. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    If the extra capacity is gained purely by the depth of the pan then the only thing you've gained over the small pan is a bit more cooling. If the gain is in width then you will have more oil to compensate for the oil loading up on top of the heads.
    Pat :k5:
  4. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    Over 6 grand with a 454, where's my flak vest?
    Pat :k5:
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Well, 6 grand is a guess. The factory tach pegs at 5 grand, and it was well past there.
  6. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    Is it smoking or knocking
  7. mountainexplorer
    Nov 14, 2001
    4,903
  8. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    its always good to have dust flying around you when you rebuild your bottom end...
    That is some hardcore shiat... i would have been running people off if they were driving by and kickin up dust. Probably would have done it in the garage tho. :cool1: :saweet: :saweet: :saweet:
  9. dyeager535
    26,980
    If you didn't change the dipstick, I wouldn't think it would be a big deal...you'd just add oil until the dipstick read "full", no? That'd be the same place in relation to the pickup no matter how deep the pan was.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and you probably wouldnt have made it to compete the next day. some of us are more hardcore than others. i've changed small block Chevys using one of those lift cranes that mounts to the bed of the truck between heats at a demolition derby before. you wanna play, you gotta pay.
