CAUTION, BUDGETING, OR BROKEN PARTS....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90STYLE, Apr 10, 2001.
  1. 90STYLE
    90STYLE Registered Member
    Mar 23, 2001
    31
    AZ
    JUST A WARNING TO THOSE OF YOU WHO ARE JUST STARTING TO BUILD YOUR RIGS FOR TRAIL USE. I HAVE HAD MY BLAZER FOR ABOUT 4 MONTHS NOW. I LIFTED IT, PUT 35'S ON IT, INSTALLED A NICE SOUND SYSTEM, AND FIXED ALL OF THE STUPID THINGS THAT GO WRONG WITH A 10 YEAR OLD TRUCK. I WILL TELL YOU FIRST HAND.... YOU NEED TO SPEND MONEY ON THE THINGS TO PREVENT BREAKAGE... AND DO THE THINGS PEOPLE TALK ABOUT ON THIS SITE. THIS WEEKEND I WENT OUT WHEELIN, AND HAD A GREAT TIME TILL IT WAS TIME TO HEAD BACK HOME. MY FRONT AXLE U-BOLTS LOOSENED UP AND KILLED THE SPRING PACK BOLT CAUSING A ALMOST TOTAL LOSS OF STEERING. I TORE THE HELL OUT OF MY ALOMST NEW TIRES CAUSE I DIDN'T WANT TO TRIM THE FENDERS. AND WORST OF ALL I (THOUGHT) I CRACKED THE FRAME AT THE STEERING BOX CAUSE I PROCRASTINATED ABOUT ORDERING THE ORD STEERING BOX BRACE. TODAY I FIGURED OUT THAT I ACTUALLY BROKE THE STEERING BOX ITSELF. THAT COST ME OVER $200.00.
    PLEASE TAKE THE ADVICE YOU READ HERE...IT WILL SAVE YOU TONS OF TIME, AGGRIVATION, AND MONEY.
  2. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Dude, backoff the caps button. If your gonna play, than your gonna pay.
    GOT ROCKS?
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    didnt have to yell...
    But I do hear ya...
    Only mine was different...
    I can go fast.... in style...
    But the speeding tickets suck...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    In case you missed this, caps means you are yelling that's all. Since you're new you probably didn't know that..... [​IMG]
    Least if you bust something you can get help on how to fix it on here and make it even better....cuz you are gonna break something. We all do....
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  5. Grim-Reaper
    7,385
    Atlanta
    Heheehe It's called being too dumb to learn form OTHER peoples mistakes hahaha. I know I'm guilty of it many times. Hopefully you sharing your experiance will save some other poor soul the same grief in the future.
    Uhhh Caps in the cyber world is called SCREAMING. It's used to inject urgency like you would talk loud to be heard. IT IS HOWEVER BAD MANNERS TO TYPE IN ALL CAPS AND VERY HARD TO READ AS YOU CAN SEE. [​IMG] Not trying to be rude too you at all just some friendly advice letting you know how it works in most message forums like the one here.
    Welcome to CK5!
    Did you get any pictures of your wheeling trip. We love sharing pictures here!
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    You should always retighten all your bolts about 5-6 times after you put a lift on so you know they are tight! They will loosen a few times while driving!
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  7. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Yup! Definitely frustrating ... not sure if it's a disease, addiction, or what ... but can't let it go!
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    10 years old I wish mine is a 74 almost as old as I'am . I guess I can just be glad I don't have as many problems...
  9. 84K5WITHAJUNK305
    84K5WITHAJUNK305 Registered Member
    Feb 25, 2001
    41
    Denison TX
    It doesn't matter what you've got, it can be broken, whether it's misuse, abuse, or neglect, it can be broken. Unfortunately, parts break more often on offroad vehicles. I'm going to go as bulletproof as possible, but nothing is unbreakable.
    A broken 84 k5 and lots of mud, it sucks to be me
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That is so true, I can't tell you how many times I opted for "good enough" (usually to save time or money) and regretted it. Usually I wound up regretting it about 20 miles from the nearest black-top. Then, my "good enough" resulted in wasted time and money (for installing and paying for the now broken stuff) plus it often broke more than just the "good enough" part AND ruined what would otherwise have been a great day. Eventually you wind up "doing it right" anyway if you don't just give up on or sell your vehicle.
    That is why I'm starting with a K30 this time. It already has most of the heavy stuff and can be easily cured of its few weak points much cheaper and easier than trying to bring a K5 up to 1-ton plus specs. I just could never convince myself to spend the money on Axles for my previous 1/2 ton trucks. Now, when I start getting creative, I can start beefing up from the K30 level instead of the K5 so I am way ahead in both time and money. Only problem is that the K30 is too long and must be cut down to fit a Blazer tub OR a add a custom body. Too bad the Bummer is so expensive.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    HEY MAN, DONT YELL AT ME!!! [​IMG] YOU ARE HURTING MY EYES!!! [​IMG]
