CB "body" Antenna?
Discussion in 'Communication (CB | GPS | HAM)' started by Hayduke, Jul 21, 2000.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    CB \"body\" Antenna?
    hey there all,
    just recently i saw a device that used your vehicle's body as the antenna for a CB radio. it looks like it attaches w/ a magnet or something then has foul wires the stick out and are soldered (sp?) to the body, then it has a antenna cable attachment point in the center. has anyone even seen/used one of these? would it even work very well?
    also, can i find mirror brackets that will clamp onto the GM style curved mirror arms?
    thanks!
    HAYDUKE
    Insured By COLT.
    http://haydukesk5.coloradok5.com
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    Re: CB \"body\" Antenna?
    THE MIRROR CLAMPS ARE FOUND AT LIEK RADIO SHACK.
    BUT I WOUL DGO WITH THE BUMPER WHIP ANTENNA. THEY GET BETTER RECEPTION AND LOOK BETTER.
    '85 K5: BIG BAD AND MEAN
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have not seen the "body antenna" for about 10 years, last time I seen it was in JC whitney. I would not trust it, I cant figure out how the thing would work since it has a load side and a ground side. If the body and frame is the ground how would it get the load? I have that Truck stops have the largest supply of CB accessories. I found the mounting bracket you are talking about that fits the curved mirror mount. Mine grounds fine and works good. I use a 1.5' firestick for trails and a 102" whip all the other times. IT hits trees and stuff so I have not been useing it alot.
