  1. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    I have a cobra 18wxst on my console and a 5foot wilson fiberglass on the rear bumper and wanted to know if there is any good place to run the coax out the rear of the truck. i had 2 wilsons on the mirrors, but i smack way too much stuff with them and decided to go to the rear bumper. I was thinking about cutting a hole in the rear pillar and somehow getting the coax through the tailgate??? Another quick question, would i be better off, now that im only running one whip, to get a 102" steel, or keep the 5 foot fiberglass. Thanks alot.
    Mud, the ultimate paint job
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I Drilled a hole in the drivers rear corner of the floor where it meets the rear floor area and ran it along the top of the frame with zip ties to the rear bumper. used a little silicone to seal the hole.
    A BIG HAMMER CAN FIX ANYTHING.... [​IMG]
  3. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    FORGOT ..The 102 in whip will hold up better then the 5 ft fiberglass. i have a 102 on mine with a heavy sping i did have to tie it of to the tail gate with a rubber strap to keep it from swing around. the strap also keeps it straight going down the road.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I just bought a CB today at a place here in town (<a target="_blank" href=http://www.chickenlipscb.com>Chickenlips CB's</a>) to replace the one I had ripped off long ago... I had my antenna in the rear bumper and and was gonna just place it back there again but she said the roof is the ideal place or on the side of the truck. I'm placing my antenna on the side of the hood by where the regular antenna is... All this place sells is CB's and they know their stuff... maybe they can get you some info...? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Quit shooting corn at me!
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  5. nofeartruckin00
    Oct 5, 2001
    798
    Thanks alot for the help. I found a gap in between the tailgate and weatherstripping to run the coax out the rear. As for the antenna, i went with the 102', and it works so much better than the fiberglass. SWAMPRNR, how did you strap it to the tail gate, cause mine is bouncing all over the place :) Thanks again!
  6. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    I used a small rubber bunge strapp hooked to the top side tail gate latch and looped it around the antenna. both hooks are on the latch between the gate and side panel.
