CB mounting kit for roof???
Discussion in 'Communication (CB | GPS | HAM)' started by XHitman396, Aug 8, 2003.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    I gotta cb, and ive always wanted to look like the truckers, mounting it between the sun visors on the roof, is there a way i can do this without drilling through it, like a kit or something. someone told me that some chevy trucks had a double layer roof, with an air gap in between, so it could be screwed into that, could my head board (or whatever its called) support the weight without sagging? thanks for your help, and if all else fails, i will drill through the roof, thanks....
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    The mounts you are talking about can be picked up from Radio Shack for about $15 a piece. The roof of your truck is double metal and you will have to drill ahole through both sheets, however you can hide the coax above the headliner and run it down inside the post. If you do not want to drill there is some clamp mounts that you can get for lip on the roof... above the door.
