Cb Pa
Discussion in 'The Garage' started by Snowman1000, Mar 26, 2007.
  1. Snowman1000
    Snowman1000 1/2 ton status
    Jan 28, 2007
    518
    Freeland Michigan
    I know this is a little off topic but im wiring a pa system into my blazer. I wired the P.a. speaker to the radio and it works so I hooked it up to my cb pa port and it works but its really quiet. I used a set of broken headphones and the wires to hook up the jack to the back of the cb.(because I needed the plug in jack) Then I hooked that up to the back of the cb.Is it a possibility that im using too small of a guage of wire and its not letting it get loud enough or do I have bigger problems.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    what kinda radio are you using? Dynamike is used as volume control alot of times for the PA outputs.
  3. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    Its just an old Corbra nothing special I will try another radio and see if that dosent help. I just didnt want to put an expensive radio in a truck I cant lock up.(no key to door locks and no rear window)
  4. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I used the same kinda wire (headphones). Mines not very loud at all either but I always thought it was the speaker. I'm sure there is some way to make it louder
  5. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Both my Burbs have a minimum 18g wire to the PA speaker, doesnt need to be sheilded. I agree with K20 that there should be something called dynamike or mike gain to control the volume output of the speaker.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Most headphones are stereo , the PA plug is mono . Enough of the connecotr may not make good connection . Go to Radio Shack and buy a mono plug , and solder leads to it .
    A PA speaker should be plenty loud with modest power .
  7. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    or make your current plug mono to test it first...just partially unplug it. There are multiple rings that the signal runs through...you can see them on the tip so just partially unplug it and see if it helps.
  8. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    I will try tomorow and maybe if im out and about I will swing by radio shack and pick one up.
  9. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Also, Make sure it is a 4 or 8 ohm pa speaker and not a commercial paging speaker that is set up 25 or 70 volts. I see these around at swap meets and people think they will work as CB PA speakers.
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    What happens if you use a speaker with too high voltage?
  11. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    The speaker does not have high voltage - it uses a transformer to convert commercial 70 volt paging loop to standard 8 ohm impedance for the speaker. Most of the time if it's a commercial PA speaker it will just be really quiet as was described.
