CB.. Where to run antenna wire ?
Discussion in 'Communication (CB | GPS | HAM)' started by njonl, Apr 6, 2004.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    I drive an '89 K5 and a buddy gave me a wilson 1000 whip antenna. I want to run the wire somehow so that it isn't so noticeable. My CB is mounted on the ceiling right above the rear view mirror. I put the antenna towards the front of my blazer and I need help running the antenna wire. Anybody have any idea's or suggestions ? Pics would help too if possible. Thanks A lot.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    did you go thru the roof with the wire or are you going to go thru the door jamb?
  3. njonl
    Jun 30, 2003
    128
    Northern CA
    I want to go anywhere that will look clean. Any suggestions ?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well if you have it mounted to the roof, you only have 2 choices.
    A)route it along the roof to an opening like a door, between topper and cab (which in my opinion will both cause leaks)
    B)drill a hole in the roof and run the line hidden by the headliner then down the A-pillar to your CB.
  5. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    If you drill the hole in the roof, you could fish the coax down the inside of the A pillar. It will come out just above the vent on the kick panel. The passenger side is the easiest.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My truck came with a NMO mount already installed bu p/o. It has wire fished through the inner panels and comes out near the floor behind drivers seat. On tht NMO mount I have a NMO to 3/8 adapter and a cheap short whip with bottom spring coil. I have whacked this on darn near every tree in AZ and have yet to hurt my body or the antenna. I even have a good match on it . When I want to go in my garage I just unscrew the antenna/adapter and all that you see on top is some threads about 1/8 high and about 1 1/2 " around. /forums/images/graemlins/k5.gif
  7. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Well, back in the 70's we installed CBs in everything with wheels and ran antenna wires to the back bumper and installed steel whip antennas or 5/8 wave top load fiberglass. But I haven't looked at anything more elaborate than welding to a vice grip to affix to the mirror mount on 18 wheelers
    /forums/images/graemlins/pimp1.gif
    I'll bet it still works
    Fred
  8. bigcat44
    bigcat44 Registered Member
    Jan 29, 2005
    59
    Albuquerque
    Just got my set-up yesterday and I am running it further back. It's mounted on the roof above the dome light, then along the plastic, down the A-pillar and to the CB. I'll get some pics up this weekend. I am running the same antenna as you on my 89K5.
