CB whip for AM/FM???
Discussion in 'Communication (CB | GPS | HAM)' started by Crunk_K5_1984, Apr 4, 2003.
  1. Crunk_K5_1984
    Crunk_K5_1984 Registered Member
    Feb 5, 2003
    87
    Kosciusko, Mississippi
    I've heard about doing it before, but I don't know if it'll be totally screwed or if it'll be like cockwork. I want to run 2 120" CB whips on the rear corners, one for my radio and one for my CB. Let me know what you guys think. Cheers!
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    The biggest thing you'd have trouble with is having too big whips swingin' all over the place
    It'll work ok. A lot of folks have trouble with a high SWR when a whip is mounted real low like on a bumper... some do some don't. The AM/FM antenna will react a little with the CB antenna but not enough to notice... It might make it bleed over to your stereo a little more than usual when transmitting.
    If you mount your antenna on the far corner of your vehicle you will have a somewhat directional antenna... Your reception will be stronger to the front than it will to the rear.
    102" is a bit overkill for the AM/FM antenna but if you want the look then go for it. /forums/images/graemlins/thumb.gif
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hook em up and give it a try /forums/images/graemlins/thumb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've seen a pair of 102's mounted off the mirrors befor. The guy used one for the CB, and the other for the stereo.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thats what im ganna do..just not with 102's..my dads got one and its a little big for me!
  6. Crunk_K5_1984
    Feb 5, 2003
    87
    What about those white fiberglass antennas? I thinks they're 4' I'm not sure...... I might try those b/c there's a lot of low-lying power lines around /forums/images/graemlins/mad.gif I wouldn't want to risk electrocution (not likely, I know but "Hey, It could happen!")Cheers!
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea or there are shorter stainless whips to. if you do it...let me know how it goes. and by the way..on a side note..how does your blazer run with 3.08's and 33's? i have 3.08's and id like to go to 33's but i think it might be cutting it..speacially with a 700r4!
  8. Crunk_K5_1984
    Feb 5, 2003
    87
    Sluggish going up hills but that's the diesel more than the gearing. You've got a 350 so you wouldn't have that problem /forums/images/graemlins/smirk.gif Steering took some getting used to after I upgraded from 31"x10.50" to this but all in all It rides and performs much better on and off road. /forums/images/graemlins/thumb.gif
  9. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    there wouldnt happen to be a connection converter to connect a cb coax cable to a radio would there? or do i have to strip the coax and add the right connection?
    on that side note. i run 3.07s and 31s and its a bit sluggish intown, takes a bit to get it going. and sucks gas. once i am going on the highway i can cruise like its nothing. of course i only have a 350/th350, i am thinking 3.23s.
  10. prerunner1982
    Nov 4, 2002
    235
    Oklahoma
