cd deck installation
Discussion in 'Audio' started by Grant G, May 27, 2000.
  1. Grant G
    Grant G Newbie
    May 17, 2000
    3
    How hard is it to make the modifications to install a cd player in a 69-73 blazer or jimmy?
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Just read the other posts. It has been discussed in detail in one just a few lines down.
    '73 K5
    Chevy good...Ford bad
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Boy, that was helpfull!! In answer to your question, It can be difficult because you have to cut thru metal. I used a dremel tool, it took a while but it came out nice. If you use a dremel tool use the cutting discs reinforced with fiberglass, and use eye protection I had one break apart at 10k rpm and pieces hit my face and cut me up ....also you are mounding the sleeve to a big piece of metal so you can get a ground loop that causes alternator whine and static. Anywhere a piece of the stereo or sleeve touched a metal part of the truck I tried to insulate it..with rubber washers or if you are desperate you can use electrical tape..good luck
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Never thought of that.
    I have this turbosound that kicks in and my reciving is shitty at best.
    I will try to insulate where the player touches the metal and see.
    Learn something every day here..
    <font color=blue>Espen88k5</font color=blue>
  5. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    The chassis os newer head unit should be insulated already. I've had a pioneer and a Panasonic now and both were metal to meatl. No noise what so ever. A lot of times noise can be traced directly to speaker wire and RCA wires running too close to power wire. If you have a jumble of wires you are bound to have noise. Just make sure you are neat about your wiring and everything will turn out well.
  6. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    Also, I'm about to remove mine fomr the dash and make me a console that I can mount the head unit in. If you go that route the unit can't play CD's at very steep angles.
  7. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I wish I had know about the cd changers for cars. I would have gotten a better tape player and threw in a changer for the best of both worlds.....my 2 pennies...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
