cd player wiring
Discussion in 'The Garage' started by stizkidz, Jan 11, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    I did about 80% of my CD Player install tonight. I cut apart the dash and fought with the old stock radio to remove it. I then hooked up a wiring harness that I wired together to connect the truck to the headunit. The headunit is a working unit, as I had it in another vehicle recently. The wiring harness that the truck has are 3 plugs. 2 for the speakers and one for the power. The wiring harness for my headunit has 3 power wires (red, black, and yellow). On my last vehicle, I only hooked up the red and black wires and everything worked just fine. However, when I plugged it in tonight, the headunit got no power at all. I checked the fuses and everything is fine. Does anyone have any suggestions on what wires I need to use from my K5 to power the headunit? I basically need to know which colors to connect from the K5 to my headunit's red, black, and yellow wires.
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    red wire = key on power
    yellow wire = constant power key on or off
    black wire= ground
    also i sugest you run new wires to the speakers because gm used a comon negitive for their speakers witch doesnt work well with aftermarket head units
  3. stizkidz
    Nov 11, 2004
    219
    Do you know the corresponding colors for the K5's power wires? Thanks.
  4. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    I think they are
    Red: Green or Gray
    Yellow: Yellow
    Black: Black
  5. stizkidz
    Nov 11, 2004
    219
    Can someone who has done this, please give me some pointers... I wired up the harness and there was no power at all. So, I ditched the harness and just hard-wired everything. I turned on the key and all I got was power to the unit for about 10 seconds. I then tried another known working Headunit and the same exact thing happened. I then checked the fuses and they were all fine - not to mention my stock radio worked fine! I found another set of wires that went to the stock radio - 1 red wire and 1 brown wire. Do I need to use these wires? Please help, I am getting very frustrated.
  6. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    You might have a bad ground, sometimes aftermarket radios need the antenna plugged in also
    from your new radio
    red = switched 12v
    yellow= constant 12v
    black= ground
    Wire it up without the speakers and see what happens. If it stays on then you know you have a bad speaker or speaker wire somewhere.
  7. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    im my truck, the meat head that had the truck before me hacked the whole truck harness. so what i did with my cd player is took the red wire and plugged it into the ignition spot in the fuse block, then grounded it with the black wire, and the yellow wire i spliced in with the cigarette lighter. it worked for me:confused:
  8. tin man
    tin man 1/2 ton status
    Nov 11, 2000
    149
    Roselodge Oregon
    I hope you have your problems fixed by now. If you don't, the fuse block idea is great. It is an easy way to identify switched and nonswitched power. I grounded my deck directly to the chassy via a bolt in the brakes I think. That way I knew the ground was good. One problem that I ran into was a grounded wire running to one of my speakers. The deck would shut down on internal protection. My solution was to run new speaker wires. Like I said before, I hope this advise is coming too late. I know how frustrating It can be. Good luck.:)
  9. stizkidz
    Nov 11, 2004
    219
    The thing that really gets me is... When I had an S-10 Blazer, I ran into the exact same problem. If I remember correctly, I had done everything up to the point I am at right now (hardwired everything) and nothing worked. I finally ended up replacing the "radio" fuse and suddenly everything worked just fine...
