CD-rom/DVD-rom, DVD burner/CD burner question
Discussion in 'The Lounge' started by 84gmcjimmy, Aug 11, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Do they have to sit level to operate properly? or could they go at an angle at 10* or more from flat? Or what would happen?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't see why not , the PS2 can be sit sideways on the optional stand .
  3. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    As long as your CD/DVD will stay in the tray, you're good to go...
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    How do I know when it will fall out of the tray. Would it be the same thing as me holding it with a disc in it. Or does it have to be running in order to test? I just dont want the disc to fall out.
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I think that might cause drive issues that the flux capacitor can't compensate for. The 10º angle causes a minute shift of the velocity of the disc, and if it's spinning at the maximum rated speed, the bearings within the drive will burn up and require repacking after only a few uses. Not only will the bearings have a problem, but the lens and laser may also have a problem directing and reading beams properly, and you end up with genocidal laser encryption in the flagellum. The encryption effect can be decoded and transferred, but it takes so long and so much effort it's almost not worth it, unless you have critical data to recover.
    I'd reommend getting a gyroscope that fits in the tray and can give you exact readings before you proceed. If the readings are between 7 and 12, you're fine, if they're more than 12, you'll have a problem extracting pcb's and data continuity.
    Good luck.
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Genocidal lasers are never fun
  7. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Tell me about it...
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright maybe I will just forget about putting it on an angle. Sounds harder than I expected.
    Thanks Ratch :)
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    On a side note Stave, Adolf Hitler was using a prototypical Wax Groove Versitile Disc (WGVD) players powered by adamantium crystals in 1944 in hopes that with the right tilt, he would in fact get that perfect genocidal laser
    Sad thing (for him anyway) is that the laser, when achieved, melted the wax off of the disc, skewing it to blast off one of his testicles.
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    What the hell are you talking about nayway, an external DVD writer for a comp?
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    No I wanted to build a triangular computer case for my future computer i am building in 2010
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    STOP PLANNING SO FAR AHEAD
    Check your CD tray,s ome actually have little tabs to hold the CD in, it will run at any angle
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I've already decided im flying into space in 2014
  14. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I've decided that in 2014 I'm gonna pull a 1967 Gibson Flying V Ta-kun like monster smash and wail you back to the ground monkeyboy
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    On newyears eve of 2014 im going to hide.
  16. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Use the genocidal lasers against him Stave...
  17. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'll exploit the power of Stave's insecurity by using the dreaded three little dots...
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    3 dots? What?
    I almost drowned today...not quite.
