CD System
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Aug 6, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    Sorry, I can't seem to be able to post a message in the Audio Message Forum.
    I just bought a Jensen cd system for the truck. I need a constant 'live' wire to make it work, is it ok to splice into the cigarette lighter wire? Also, how easy is it to access the front speakers on top of the dash, and there are only 2 right?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yes you can splice in to the cig lighter and it is really easy to get in to the front two speakers..........Dan
    If it ain't broke.......Don't fix it....
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can splice into it with no problem - I prefer running a new lead off of the fusebox at any rate, since lighter circuits tend to be somewhat touchy.
    Friggin Silt![​IMG]
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    Depending on the year of your vehicle you may only have one dash speaker(like my 73). The dash comes out pretty easy and the speaker comes right out the top.
    I have a question about the fuse box myself. Mine has a few plug-ins that I am guessing are for accesories. Does anyone know which ones have constant power? If I cant find one I will run a lead all the way to the battery. I changed my radio out sunday and Im pleased with the sound for now(some sound is better than no sound).
    73 K5, 350, auto w/factory air, 4in susp, 35's
  6. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Just checked there is a 20 amp fuse on the top of the panel marked 'accessories' (the text is to left of the fuse) and the blade (male connection) under it is a constant positive feed on my 73.
  7. Chaz316
    Jul 25, 2001
    224
    Georgia
    Hey thanks Aussie. I'll swap mine over after work.
