CD's are skipping, help
Discussion in 'Audio' started by ftn96, Apr 10, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    CD\'s are skipping, help
    New Rockford head unit. Mounted in dash with adaptor plate, home made out of sheet metal. I know the lifted blazer with BIG A$$ mud tires isn't gonna ride all that smooth, but man this unit skips at every little bump, even dips in the road.
    Hell, it skips when my tranny goes from 1st to 2nd. What can be done? Note: I dont have any sorta strap on the rear of the unit back behind the dash area. Could this be the item I need to stop this? Thanks!
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: CD\'s are skipping, help
    i would think that some strap metal wouldhelp stabalize the unit from skipping as bad as it does, but does fosgate say that it has any sort of anti-ship mechanism?
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    non that I re-call reading about
  4. zcarczar
    Feb 10, 2002
    2,495
    hmmm.. i would try using the strap steel to brace it and make sure you cant wiggle it at all after you get it in and braced because that will lead to the notorious skipping for sure
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I am not a fan of Rockford Fosgate. I'd personly consitter swapping it for a JVC, KENWOOD, SONY, PIONEER, ...ECT. I think you are paying more for the name then anything else with RF.
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Swapping is not an option less you have the money to donate
  7. zcarczar
    Feb 10, 2002
    2,495
    is the units warranty stil good? if so i would contact fosgate and tell them your problems if any other solutions dont work because it could end up being a defective unit
  8. ArizonaK5David
    ArizonaK5David Registered Member
    Mar 19, 2002
    32
    Gilbert, Arizona
    Well, I have done a "custom installation job myself, it is possible that your cd player is mounted too firmly to the truck, as dumb as that sounds, and it is picking up every little vibration. If you are willing ;>) trim your custom stereo mount a little bigger than the deck, get an bicycle innertube and wrap it around the deck once or twice where it makes contact with your mount. That should eat up most of the vibrations that your sensitive fosgate deck whines about. There are other types of insulators you can come up with if a bicycle inner tube is just a little too "white trash" for ya!
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I'll try the rear strap first and see what that does.
  10. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Truant CD's are no laughing matter! I suggest the most strict form of discipline!
