Cedar Fence Post Help
Discussion in 'The Lounge' started by Cricket, Mar 7, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Anyone have a whiz bang idea for removing old cedar fence posts set in 2 ft concrete plugs?
    Got one out today by digging around it and sledging. When it got too deep for the sledge I pounded a steel bar down through the rest of the old wood and concrete then pulled out the pieces. That is a time consuming PITA. Only other idea I have would be to use the big jack - nail a 2x4 piece to the post and try to jack it out.
    If you know an easier way besides explosives...........:1zhelp:
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Depending on how many need removing it may be worth your while to pay for a backhoe to stop by for a couple of hours.
    What kind of ground are you in?
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Use a strap and a high lift jack. that's how I got out an old satellite dish in 4FT of concrete
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    the utter lazy mans way (my favorite), cut the posts off, cover the concrete plugs in dirt, and 4get aboutt it.
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I'm assumin you can't get a vehicle nearby to yank them out?
  6. Cricket
    Nov 29, 2004
    8,224
    Colorado
    First 6" are soft dirt mix, next 18" plus are hard clay mix. Not rock hard but hard enough to slow digging up.
    Backhoe is out of the question, I'm in a residential neighborhood with houses in back and both sides. As it is I am just removing a few face boards at the post, prying the cross supports away, crawling through to the neighbors' yard and digging from there - the post side. I've got to minimize the damage I do. I kept the hole diameter within 10-12 inches of the post itself because I don't want to trench someone else's yard, or garden. It's a catch-22.
    The high-jack and strap Big Pappa B mentioned may work, thanks I'll try it tomorrow. ADDY: the posts are rotted away at ground level so it may or may not work.
    Worst case I could trench my side of the fence post and then pull it towards my yard.
  7. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Yep, I'm in a bad spot. No way to get a vehicle close.
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Strap it on, maybe a nail it the post to keep the strap from sliding up. Also put a block on wood under the jack to keep it from pulling down into the dirt
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Strap it on, maybe a nail in the post to keep the strap from sliding up. Also put a block on wood under the jack to keep it from pulling down into the dirt
  10. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    how bout an engine hoist and a strap?Just dig down enough to get the strap around the concrete and hook er up to the hoist.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I vote for Black Powder and short fuses!!!:D
  12. Cricket
    Nov 29, 2004
    8,224
    Colorado
    3 on the tree: good idea if I only had a hoist handy I think that would work.
    Dontoe: Short fuse eh, like 5 ft on a 5ft per sec burn rate.:D
  13. Cricket
    Nov 29, 2004
    8,224
    Colorado
    New Tack
    This morning I dug a 2 ft pit on my side of the fence, that's the depth of the plug on average. Then I used a crowbar to pry the slug over toward my side which gave me room to pop it with a sledge. 3 hours from start to finish including post replacement and new concrete. Went faster that way.
    If you have the patience to chip through the hard clay......
