cellphone coax for cb
Discussion in 'Communication (CB | GPS | HAM)' started by danielzink, Jul 19, 2003.
  1. danielzink
    danielzink Registered Member
    Nov 11, 2002
    14
    The PO of my Suburban had one of those old "bag" phones and ran coax from the front to the rear roof and mounted a base on the roof.
    The coax is still there and if I remove the base...we...I'll have a hole in my roof.
    So, can I use this coax run and the base for a cb install ?
    Thanks, Dan
    87 Burban
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    You will have to change the connectors or get adapters but the coax will work just fine for CB or basically any other type radio. /forums/images/graemlins/thumb.gif
  3. danielzink
    Nov 11, 2002
    14
    I took a quick look around today. The mount that is on my roof has a male end sticking out of it. The CB antennas that I've looked at all seem to male ends coming from them. Any ideas as to where I could get a female to female connector or a CB antenna that has a female end on it ?
    thanks, Dan
  4. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    hmm....... Normally a cb antenna has a female UHF(PL-239) type connector on it. The radio and antenna both have female ends and the cable normally has males at both ends. Cell phone antennae normally use a TNC type connector on them (Also female IIRC). Either way you should be able to find the connectors and/or adapters you need from Radio Shack.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    thanks, Dan
    [/ QUOTE ] Easy, cut the ends off and put on the ends for CB.
