cement/concrete
Discussion in 'The Lounge' started by 84gmcjimmy, Jun 6, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Always get these 2 terms mixed up. But my friend just got there basement and carport cemented/concreted in. (before it was dirt) and I was wondering something. How do you get the different surface "texture" (ie fine grit or coarse grit finish) like a carport or wharehouse floor which is smooth as can be. And a regular slab of cement/concrete for sidewalks, etc.
    How do they get it really smooth, and semi-smooth from it being really rough to start off with? Do they use more sand and less gravel?
    Also just so I don't sound like an idiot, whats the difference between cement and concrete?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    As it starts to cure the workers begin to trowel it with a large machine that has 4 trowels on it and they rotate if you want it rough sometimes the drag a shop broom across it to create the texture. Also cement, is what is added to agregate (rocks) and sand to make concrete.
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Cement is concrete before it hardens.
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    What really sucks is trying to finish a large slab without a power trowel. I poured concrete before joining the Air Force and we rarely had the privilege of using a power trowel.
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    negative... sandawg had it right...
    j
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright thanks sanddawg. So to make the texture they have trowels?
    Thats neat. Thanks :)
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Always done the shop broom trick, always worked fine for us. I didn't even know about power trowels. :crazy:
