center bolt heads
Discussion in 'The Garage' started by mostwanted, Apr 27, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Would the center bolt heads on my rig be vortech? If so are the rocker arms and stuff be the same as any other GM head?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the vortec heads only have 4 bolt holes on each head for the intake, if it has 6 holes for the intake, they aren't vortec heads.
  3. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    what about the intake ports? A friend of mine said vortechs are oval.
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    big blocks maybe, but not gen 2 small blocks, they are still rectangular. And the Vortecs take the self aligning rocker type set up, and just because they are centerbolt doesn't mean they are vortec. The vortecs came in 96 up applications.
  5. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    that's what I needed to know. I know I either need head work or have bad rings as I am loosing compression on 1 cylnder. If I am going to tear into it, then I want to build it the way I want. Planning on Vortech heads with a comp cam XE262H grind cam.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    vortec engines are still considered gen I
  7. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    mmmm I was thinking the Gen 2 started with the LT1 and centerbolt valve covers.
    But I'm old.
  8. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    LT1 is gen II... but vortec is gen I. Optispark and reverse flow cooling are whats real different about the gen II from the late gen I's.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The LT1 has been around since the 70's, i think you're confusing it for the LS1.
  10. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    no, there is a 'new' LT1. used in b-body 94-96, camaro/firebird 93-97, vette 92-96. Called the Gen II smallblock. LS1/LS2/LS6 and the truck 4.8/5.3/6.0 are gen III.
    Trucks/vans never got Gen II motors. Vans were gen I until '02 or 03.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    The LT1 in reference here is the 92+ Vette/Camaro/Caprice multiport engine. Come on, you know that.
    LSx engines are Gen III engines.
  12. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Digging further back in my memory... I pulled this little tidbit out of... well... the far reaches of the back of my head... the 70's engine you were referring to was actually monikered the "LT-1" while the gen II is actually "LT1"
  13. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no 94, is TBI engine, not vortec. Vortec started in 96 for v8s.
  15. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    ok thank you.
  16. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    true but....
    ......in 96 the vortec was an option so all '96 models aren't vortec. regular tbi motor was standard, vortec was optional motor in 96...vortec was standard in 97!
  17. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I'm not sure where your info came from but everything i know of says 1996 was vortec. The last regular TBI was 1995
  18. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    i know this because i have a 96 tahoe with a vortec and i also have the window sticker of said vehicle that shows the vortec as an option and also have a friend with a 96 that his dad bought new as a base model and it has a regular tbi in it
    1996 - This was the last change for the Generation I engine, and continued through the end of the production run in 2003; all 1997-2003 Generation I engines were Vortec truck engines. The cylinder heads were redesigned using improved ports and combustion chambers similar to those in the Generation II LT1. This change resulted in significant power increases.
    it says all 97-2003 because in 96 tbi or vortec was available
  19. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    TBI L31 applications
    1996 G-series Vans over 8,500 GVW w/ 4L80E\
    1996 General Motors C/K full-size trucks
    1996 Chevrolet Suburban/GMC Yukon XL full-size long-wheelbase SUVs
    1996 Chevrolet Tahoe/GMC Yukon full-size short-wheelbase SUVs
    L31 applications:
  20. dyeager535
    26,982
    191
