center console lock ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Feb 1, 2003.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I need to replace the center console lock and was wondering if anybody knows how to take it off without damaging the cover. Any help will be greatly appreciated.
    Thanks,
    Ray
  2. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    Good question! TTT
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup I need to replace mine too TTT
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    If it's the type that doesn't actually use a key, look on the back side near the latch hook, there's a small slot, I think it's about 90 degrees from the latch, using a small pointed object push in the catch in the slot and the outer part will pull out of the latch, the center section will then unscrew to remove it from the lid.
    If it is the keyed type it works pretty much the same but the key has to be in the cylinder to remove it.
    It's been a while since I did these and this is from memory, let me know if I forgot anything.
