Center console mounting
Discussion in 'The Garage' started by RubberFloorMat, Feb 1, 2006.
  1. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    395
    43
    Oklahoma
    so...my truck didnt come witha factory center console, found a mint one at the salvage yard, how the hell do you mount these things, is there a bracket or something???
    the yard didnt have one...and i looked in the burb that it came out of.
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    there is a slightly raised bracket for the back... heck, i've got an unused one floating around the garage somewhere. i'd send it to ya if i knew where it was...
    2 bolts up front go right thru the floor. the bracket bolts to the floor, then the console to that.. it only sits up about 3/4" or so.. you could prolly make a couple spacers to go under the rear mounting holes to take up the gap...
  3. RubberFloorMat
    Dec 12, 2004
    395
    43
    Oklahoma
    so the bracket mounts to the floor and the console to that huh...
    are they metal or plastic??
    5 months ago there were like 4-5 burbs and a k5 at the yard, now they are all gone..
  4. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    metal.. its about an inch wide and like 8" long iirc... runs from side to side, kinda across the end of the hump... kinda like low tab, steps up, goes across, steps down, low tab.. has welded nuts to it for the console to bolt to it...
    like i said, maybe a couple blocks of metal, or plastic drilled and run the console bolts right to the floor...
