Center drop, passenger side exhaust manifolds?
Discussion in 'The Garage' started by BadDog, Jun 29, 2003.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, doubler is going in this weekend (FINALLY) so I am now forced to change my exhaust from the factory Y pipe. I don't want duals and I absolutely despise headers. What I have in mind is to switch one (or both) of the manifolds to get a center drop on the passenger side, and run it under the oil pan to Y in on the drivers side before going back to a single 34” glass pack. Rams horns are an option, but maybe there is something else?
    So, what are my options? These are my criteria.
    1) Driver and passenger drop straight down the middle. If I can keep the modern manifolds (under bottom with air injection) I can just keep my driver’s side manifold.
    2) I would rather just get a passenger side and use stock type as close to my 89s as possible to keep air ports and all. Maybe a Van or something?
    3) Diameter is not a huge deal with my stock TBI 350. I don't much care about high rpm power, I doubt it will ever see over 4K anyway.
    If Rams horns are the best options, what years and part numbers for the smaller (2”?) diameter versions. I asked that before on another post but I don't believe it was ever answered. Link to that post is below.
    Old post
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the passenger side ramhorn is 129.00 and the drivers is 109.00 at oreilleys. i just went with headers. my friend had some jaguar manifolds that he was gonna let me use. one of them dropped down in the center. they are now on another truck though. but its an idea
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I did the opposite. Ran the drivers side center drop to Y into the passenger side and to the outside of the frame by the shackle. Would be easier to just Y in and run it inside the frame and back unless your all clocked and in the way.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmm, Jaguar? Is that for a SBC transplant or something?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I can't go down the passenger side due to the clocked 205 and my fuel lines/filter right there by where the 205 is now located. I wanted to run outside the frame and, a long time back, that was my plan. But since then, I built my sub-frame which does not allow enough room to do that. I also have damaed my floor sheet metal up INSIDE my rocker bars so, exhaust would be vulnerable in that area, even if I could tuck it up enough. My only real option right now is to go down the drivers side inside the rail. Plus, center drop on the passenger side keeps the starter cooler too...
    Thanks for the suggestions, please keep them coming. /forums/images/graemlins/thumb.gif
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Ram's are a good choice. Here's the set I had on my crewcab. Note the minor clearancing at the driver's engine mount.
    other pic 1 other pic 2
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    u2slow:
    Actually, yours was the picture I was asking about in the other thread. You've even got the same TBI 350. What was the application you got yours from? You have the 2" version? Part numbers maybe?
  8. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Hey Russ,
    I should be able to get you what you need. New aftermarket only, though. Call me at work if interested.
    See ya.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Cool! I'll call tomorrow.
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    My manifolds went with the engine. /forums/images/graemlins/frown.gif (they were 2" BTW)
    I looked up 72 K20 exhaust manifold on www.Car-Part.com and it returned 4 pages of hits. Half were new parts - $77 seemed to be the going rate.
    The application for these 2" straight-dump ram-horns seems to be 69-72 4x4 truck, 75-79 Corvette, and 69-70 fullsize car.
