center link
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by imconfused, Jul 2, 2000.
  1. imconfused
    imconfused Registered Member
    Jun 16, 2000
    44
    Can someone please tell me where I might be able to find a new center link( also called adjustable link) . This is the 52 inch bar that turns the front wheels . I have found a couple but they include the drivers side tie rod(non-adjustable) as part of the unit .(mine has adjustable tie rods on each side). The problem is that the catalogs state that this unit is ONLY for use with 4.10 axle ratio(I can't imagine what that has to do with the steering!!) unfortunately I can not find a listing for that piece for non 4.10 axle ratios. Last of all ....I just had my alignment done and the shop told me that I needed to replace as it has a small bend in it and will affect the steering ....I'm not sure this is correct . Thanks again for a GREAT site !!!!
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    MY "TIE ROD" CENTERLINK HAS HAD A "BIG" SMALL BEND IN IT FOR YEARS AND YEARS. SOUNDS LIKE THE ALIGNMENT SHOP IS COVERING THEIR ASS. BASICALLY YOU WANT TO MEASURE BETWEEN THE FRONT TIRES IN FRONT AND IN BACK AND GET THE SAME DISTANCE. (63 IN AND 63 IN) OR WHATEVER IT IS. OR JUST TAKE IT TO ANOTHER SHOP. GOOD LUCK
    creepin' and crawlin'
    Jim
  3. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    Just in case you need a new one, think LMC truck offers them at $90.
    http://www.lmctruck.com/
    (one day I will find out how to make it clickable)
    Balou
    '79 K5,350,465,205
    [​IMG]"Size DOES matter!!!" said the girl last night [​IMG]
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Balou...when you are making a post, in the upper right hand corner of the page is the word "markup" click on this for the different things you can do, like change the color to <font color=red>RED<font color=black>to make it clickable place a bracket ( [ )then type in url then the other bracket facing the other way. Then type in the url, do not add the http it will do this automatically, then at the end make a another bracket and type in /url then the other bracket. It should look like this without the parenthesis...
    ( [ )url( ] )www.lmctruck.com[/url]
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  5. Balou
    Apr 15, 2000
    207
    back to Germany
    Thanks a lot Ray,
    went through the whole story in FAQ several times, but still do it wrong when posting.
    Whooowwwww, you made it "old hand", what's next?
    "pooh pah" ??? hehehe
    Balou
    '79 K5,350,465,205
  6. Balou
    Apr 15, 2000
    207
    back to Germany
  7. Balou
    Apr 15, 2000
    207
    back to Germany
  8. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Don't worry about the bar having a small bend in it, it can still be aligned and won't affect your steering. I've seen race trucks with tie rods shaped almost in an s-curve to clear the a-arms. All that matters is that each end moves the same amount, what's in between can be any shape. Severe bends on the other hand should be replaced because of the stress concetrations they create and it can shorten the effective length of the bar enough that the toe-in can't be corrected.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  9. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    NAPA will have one. I think they were on the older fullsize trucks. 84 and older rings a bell...
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
