center pin bolt broke!?!?!?!
Discussion in 'The Garage' started by big83chevy4x4, Apr 29, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i was changing rear axle seal and i took the center pin bolt out and it is only 3/4 inch long and it looks like it has been broke for a while. /forums/images/graemlins/angryfire.gifsomeone must have broke it off when putting it back together or when trying to fix the leak. /forums/images/graemlins/angryfire.gif is there a way that i can get the rest of the bolt out so that i can change the seal. the seal leaks very bad. been sitting for 3 days and there is a lot of fluid sitting inside the drum. i don't want to put back together and with out fixing it. HELP /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    Re: center pin bolt broke!?!?!?! NEED HELP FAST
    You could drill into it and use an easy out They usually work for me
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the hole is to close to the housing to get a drill in it to drill it out. i found a complete rearend at a junkyard for $100 so..... looks like im doing a rearend swap. the hard part is that it is in a s10 blazer and the housing is over the springs /forums/images/graemlins/eek.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> An S10 axle is not going to fit your truck. Jut pull the carrier out and remove the piece on the workbench, no need to replace an entire axle because of one broken bolt... </font>
  5. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    actually if the bolt is broken off and holding the cross shaft in place there is no way of getting the carrier out because you can't push the shafts in to get the clips to fall out. sounds like a crappy deal......go buy a 90* drill and drill it out, I'm sure you can pick one up for under 100 bucks.
    -Scott
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    [/ QUOTE ] the bolt that broke off is in a s10 blazer.
    [/ QUOTE ] thats exactly what happened.
    [/ QUOTE ] i totally forgot about those. i'll try that. /forums/images/graemlins/thumb.gif
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How much of the threads are still in there?
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im not sure but there is still about 1/4 inch before i hit the center pin itself.
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Ouch. I reallyscrewed the pooch on this thread. Not reading carefully and not thinking before writing, all in the same post. I'm going to go kick myself in the ass for awhile now. /forums/images/graemlins/crazy.gif </font>
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I had that happen to my 12B. I had to take the bearing cap off to get a drill in there. It is a common thing to happen!!!! After I drilled a small hole in it I was able to get a EZ-out in there.
    If you can't do it the way I did it (EZ-out) you have to BEAT on the center pin till you shear the center pin bolt!!!
  11. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i just did mine in my s15 truck about 6 months ago when i blew my spiders. i went to remove the little bolt and it was broke. so what i did , is loosened up the bearing caps on each side which brought the carrier housing out about
    an inch. then i was able to take a chance and drill into
    the center of the little bolt (what was left inside), using
    a aicraft bit (longer bit).(cant remember the size ). then i used and easy-out and got lucky and was able to remove what was left. good luck .
  12. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
    I had the same problem and this is exactly what I did. You need to put some jack stands under the rear axle so the tires are off the ground (Don't forget to block the front tires!). Then put the truck in neutral and rotate the rear drive shaft so you can easily access the bolt with a drill. Drill into it and tap in your ez-out and back it out of the hole. I found a new replacement bolt at a local Chevy dealer for $3. Good luck /forums/images/graemlins/thumb.gif
