Center pin for springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Aug 8, 2001.
    Just wondering where to get a set of center pins for my springs.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
    <font color=black>From Kentucky
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I dont knwo that you really need to get a set of "CENTER PIN BOLTS". I'd say you'd be fine using some general grade 8 bolts from your local machine/bolt store.
    Does anyone have a grinding disk I can borrow?[​IMG]3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    You could probably just use some 3/8-24 socket head cap screws. It will be allot cheaper than going to a spring shop and getting center pins. The 24 is the fine thread. You could use 3/8-16 but I would recomend the fine thread for center pins. It's harder for it to loosen up on it's own. Just my $.02
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, what he said. also those damn center pin's normally dont have bolt heads on them and they are a pain to keep still while your tryinh to get the nuts off. Not that you'd really want to have to take them out again, but should you need to having a regular bolt head on there would be great to prevent it from turning while your getting the nut off.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have been using allen head bolts from the local Industrial Bolt store. They have an externally round head just like the factory ones, being they are the allen head style and you can get them in any lengths with a lock nut!
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  5. What are you talking about? "getting your nuts off" I don't know about you people sometimes !! Thanks for the info !
  6. californiak5
    Oct 25, 2000
    820
    Hey Mike,
    You just perfectly explained what a Socket Head Cap Screw is. [​IMG]
    See Ya,
    Keith
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Oh, 10-4! [​IMG]
    Mike
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    did you have to drill the spring retainer plate to provide additional clearance for the bolt head? seem the bolt head would be much taller than a centre bolt, no?
    sounds like a better way to go though
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Didn't have to do anything. The diameter of the bolt head was about the same size as the center bolt head and fit righ into the spring pad hole...
    Mike
  10. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Most 4 wheel drive and RV stores carry them.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Bought my last pair from NAPA. The counter folks at the other chain stores looked at me like I was asking to buy plutonium. [​IMG]
  12. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I am glad you posted this Harvey. I need the same thing for both of my rear spring packs.
  13. I'm gonna use the Key socket head screws ( Allen bolt for u and me that know them as that) I need to clean up my leaves and just wondered what would be the best thing to use.
  14. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I used allen head bolts 3/8" shank and 1/2" head works great and is as strong or stronger than center pins used in stock springs.
    [​IMG] [​IMG] [​IMG]
