center pin hole diameter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Mar 13, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Making up rear spring perches also.
    How about the centering pin hole diamter for a set of rear springs?
    Anyone have an old stock perch or a non installed 14 bolt laying around to measure the hole for me?
    Ken H.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Re: center pin hole diameter
    Mine are exactly 1/2 inch. I just made some spring pearches this past weekend out of 2 1/2 inch square steel 1/4 inch thick.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine were over 1/2". I used a 9/16" and they fit great.
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    ever get that 3/4 ton gear in yer junk yet ? ? !!
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Almost! I got the rear axle under it w/ the disc brakes on...now I found out I have a cracked leaf in the rear so I have to swap out the springs. Then weld the perches and shock mounts, install brake lines, swap the front...
    I hope to have it all done in 2 weeks (including new driveshaft)
