Center pins.
Discussion in 'The Garage' started by smokkey1, Jan 5, 2005.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I can't find any at the local parts stores around here. I'm going to go to OSH tommorrow to get some Grade 8's. What size do I need? it's for the rear which is 56" springs.
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you mean the the rod through leaf packs ?
  3. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All the ones I've ever seen are 3/8", but i've heard of some being 5/16"
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    dumb question but is that the head or the shank of the bolt?
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Any spring or suspension shop will have those...
    Chev are 3/8", anf the ones for the Ford 57" springs are 7/16"
    Rene
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I just used a socket head cap screw of the correct size. I think it was 5/16. No problems with it. I bet Steve from ORD could give you a good answer to this question. Post up in his message forum.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    go to a spring shop dude, they have em in every size you'd ever need. prolly cheaper than a hardware or parts store too...
    j
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks guys, I checked auto zone and Kargens yesterday one guy thought it was for the brakes [​IMG] then went to kargen and told me to check the junk yard [​IMG] well I'll see if there is an NAPA close by then if they don't have them I'll look for an suspension shop in the area. if not theres always th junk yard:haha:
  10. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I just did a home brew shackle flip and had to cut the old center pins to put longer ones in for the angle shim things and they were a 3/8 bolt with the 9/16 head so you use a 9/16 inch wrench of your favorite flavor.:grin:
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Don't waste time at a junk yard for parts like that...makes about as much sense as looking for an oil filter at a junk yard.
    Grab the yellow pages and find a spring shop. The center pin's run under $3 each here.
    Rene
  12. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I get them for $1.50 ea down the street. If you need let me know and i will mail them out to you
  13. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks.
    rene, I was joking about the junk yard. it's just was funny that the guy at kragen told me to go to the junk yard.
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks for the offer :waytogo: I'll keep you in mind.
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I had the same problem. Just used grade 8's and ground the corners off to round out the head a little.
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just use socket head cap screws. They are stronger anyways.
  17. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I know the GM dealers carry them. Sometimes they are a little higher but it beats driving all over the place. I bought some from the GM dealer not so long ago for 3-4 bucks a peice if memory serves. They were about 10" long. You cut to the length you need after cranking them tight.
  18. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Did the same thing..works great:D
