Centerforce Clutch
Discussion in 'The Garage' started by ramses, Aug 1, 2006.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    Im replacing the clutch in my truck for my hydro conversion and I thought about buying a centerforce clutch for it, but im not sure where to order it from. I see them in some magazines but ive never seen them for my truck before. Also if anyone has used one before, are they worth buying? I plan on getting one if I can find where to buy it either way but some opinions would be nice.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I like mine a lot and would recommend it. The cheapest prices on them are probably on jegs.com or summitracing.com.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i just went to autozone... $120 or so..
    generic clutch, pressure plate, throwout bearing and lifetime warranty...:bow:
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I would rather not pull my 465 out every 6 months to take advantage of the warrenty on a bad clutch:doah:
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I have a Dual Friction in Patch, the Wonder Yota. Most of the time it's ok, but once in a while for no appearent reason it will really grab. Like, REALLY grab. Overall I'd be happier with something else. Next time I'm going to try Marlin's clutch kit (which helps you none at all).
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    guess you gotta learn how to drive a stick.... :haha:
  7. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    do yourself a favor and get a LUK clutch instead. You beed to be able to slip your clutch to some degree. Every CAR that I have ever driven with a centerforce was either on or off... very little slip. I have abused my luk for a couple of years now without one issue.
  8. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    the guy who taught my auto-tranny class said he had one a while back. said he couldnt kill it, went through 2-3 transmissions but the clutch kept on going (this was in a mustang 5.0 he had to race). he said the same thing about being very grabby though, not much slippin' to go round. and he's the foremost person on transmissions ill prolly ever meet.
  9. ramses
    Jul 2, 2004
    238
    West Virginia
    So would it be hard to daily drive a truck with a centerforce clutch in it? Would that mean it would be really jerky everytime you take off or can you get used to it and drive it smoothly? I need something better than stock but I dont need it if its gonna make it aggravating to drive everyday.
  10. koldsimer
    Jan 10, 2005
    1,480
    texas
    I bet you could get used to it for street driving but you will still suffer off road to some degree. If all you run is mud and you drop the clutch a lot to clean the tires out, then get the centerforce. If you ever see yourself in a tight, steep or generally technical section off road, get a Luk or other good quality clutch. I can't count the number of times I have had to slip my clutch... pulling out stucks, starting/stopping on steep grades, slowly working up something, etc.. Centerforce clutches are great for the street but aren't the best choice for most wheelers.
  11. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    my bud is running a centerforce clutch on his 77, and it works awesome for everything a little harder to ride it for in town but in the bush its killer man.
  12. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
  13. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I ran a Centerforce 2 in my old dd Toy. If I did it again, I would have gone with the Double Friction, the 2 didn't seem much better than stock. I could still slip it fairly easily.
  14. ramses
    Jul 2, 2004
    238
    West Virginia
    Can someone tell me the differences between the 1, 2, and dual friction clutches and their advantages so I will know which one I will need?
  15. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
  16. 1977k5
    May 26, 2003
    9,992
    130
    My experience with my centerforce II is that it is better in every way. It grabs harder (when I need it to), it engages smoother, pedal pressure feels lighter, etc. It does drive differently than a stock clutch but you would be happy with it on the street.
